RV.Net Open Roads Forum: Class B - Camping Van Conversions: Generator
Rocksolid
70810
Posted: 02/03/20 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
Hi yall! I'm stomped. I purchased a 5500 watt generator to run my 13000 btu roof top AC but it struggles then trips the breaker. When plugged in to 120v from my home all is good.
I've tried dropping all breakers inside the RV but the problem continues!
Any suggestions! Thanks to all in advance
2oldman
Ca
Posted: 02/03/20 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Although rated at that wattage, it probably doesn't output all the necessary amps from one outlet. Gotcha.
I bet that's a loud one.
jdc1
Riverside, Ca
Posted: 02/03/20 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Unplug or turn off your Converter. That's drawing a lot of power. Maybe turn off the fridge too.
time2roll
Posted: 02/03/20 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Does this 5500 have a 4 pin outlet for 240v appliances?
Yes the converter and possibly the electric water heater are drawing a lot of power.
675w Solar pictures back up
gbopp
The Keystone State
Posted: 02/03/20 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
What is the make/model of your generator?
Maybe someone owns one and had similar problems.
KD4UPL
Swoope, VA
Posted: 02/03/20 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with this assumpiton. You can likely only draw 2,750 watts from each 120v outlet. That's if 5,500 is the continuous rating which it probably isn't. 5,500 is likely the surge rating. The continuous rating is probably 5,000 or less so you can only draw 2,500 or less from one 120v outlet.
Giving the brand and model number would get you a lot more useful advice. Everyone here is just guessing.
Rocksolid
70810
Posted: 02/04/20 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Tks. It's a Predator 5500
2oldman
Ca
Posted: 02/04/20 10:31am Link  |  Quote  |  Print  |  Notify Moderator
I can't find that generator online.
stickdog
Somewhere, USA
Posted: 02/04/20 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
Harbor freight brand.
9-11 WE WILL NEVER FORGET!
17 MS 36 RSSB3
Gone 04 HH DA LS 33.5 RLTG
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
2oldman
Ca
Posted: 02/04/20 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, but not in a 5500 watt version.
