RV.Net Open Roads Forum: Truck Campers: Rear Porch
 > Rear Porch
Go for Broke
Colorado
Posted: 02/04/20 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
In response to a separate topic it was mentioned that the tailgate should be left off and some sort of porch could be built. This idea has merit and interest me.
Would you be kind enough to share your thoughts, designs and especially photos on the idea of a porch?
Pros/Cons most welcome.
Thanks Y'all,
northshore
northshore
Posted: 02/04/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
We used to have a short bed camper, and we used the hitch receiver cargo carrier, worked great as a step/cargo carrier. We stored our generator, and a variety of other items along with using it as a step.
https://www.amazon.com/MaxxHaul-70108-Aluminum-Carrier-Receiver/dp/B008CE0LIC/ref=sr_1_6?keywords=receiver+hitch+cargo+carrier&qid=1580854075&sr=8-6
https://images-na.ssl-images-amazon.com/images/I/41rJxpyx5gL._AC_.jpg
cheap, easy to use, (get the Aluminum one ) unlimited options on what you can do with this, adding boxes, steps what ever.
ticki2
NH
Posted: 02/04/20 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Y'all,
You would do yourself a great service by taking the time to look through " truck camper university " in the stickies at the beginning of this section . It addresses many of the questions you have posted . It will not answer all your questions ,and I am not suggesting you don't ask questions , but it will give you a good background in a subject you seem to lack much knowledge , namely , truck campers . There is a whole section there on the topic of porches so you can see what others have done . Your questions and the answers to them will be much more meaningful to you .
'68 Avion C-11
'02 GMC DRW D/A flatbed
Go for Broke
Colorado
Posted: 02/04/20 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
ticki2 - Will do. Thanks for the referral.
mellow
Salisbury, MD
Posted: 02/05/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
https://www.truckcampermagazine.com/ques........truck-camper-porches-and-decks-revealed/
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
RickW
Sacramento CA
Posted: 02/05/20 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
I use a hitch cargo carrier and built a box/step on it for entry. I can get in with one large step but usually use a 2 step stool for 3 steps total. I stabilize the carrier with small chains to the TC on each end.
A milk crate with plywood on the bottom also works as a step and is my back up. Make sure you have an outside handle on the TC to grasp.
Rick
04 GMC 1500 4X4X4
04 Sunlite SB
Posted: 02/05/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
I read your other threads, don’t recall the porch discussion, but there’s no reason to remove your tailgate unless you wish to, or if there’s some part of the camper hanging down that would conflict with the tailgate.
Also if you have decent mud flaps paint damage is not an issue either.
Not really certain the feasibility of a “porch”. It would be extremely challenging to build something large enough to use that folds up and isn’t obtrusive.
mellow
Salisbury, MD
Posted: 02/06/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Having a porch is awesome, especially if you are at the beach and have a rear door camper. Not that hard to build one either, my friend bought an aluminium floating dock for jet skis and removed the floats and installed hinges to the back bumper of his 1181 and installed straps to the rear jacks for support, he can fold it up easily and roll out, he installed brake lights on the bottom of the porch so when it folds up he doesn't lose that.
Posted: 02/06/20 10:26am Link  |  Quote  |  Print  |  Notify Moderator
^Yup if you can dream it , you can build it, sounds like it works well for your friend, but I’ll let the lack of “porches” on the back of TCs in general speak for itself and the limited usefulness of them.
Camper_Jeff_&_Kelli
Seattle
Posted: 02/08/20 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Here's my slide out rear deck. Works great!
Slide Out Rear Deck.
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
 > Rear Porch
