RV.Net Open Roads Forum: General RVing Issues: Cleaning your AC Filter
 > Cleaning your AC Filter
DarkSkySeeker
Freestone, California
Posted: 02/06/20 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
I just saw a video where the RV owner washes his AC filter to improve air flow. In my experience, even a clean filter is so restrictive that it severely limits air flow. In fact, on the hottest days I just remove it and the flow seems to go up about 25%. Is this something you've done?
There is something special about camping in an RV.
cavie
Posted: 02/06/20 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Never and it's just plan stupid. Without the filter you are allowing the dirt to collect on the coils instead of the filter and blocking air flow thru the coils!! You cannot get to the coils to clean without going on the roof with special coil cleaner that is hard to buy and unsafe to use without proper training.
poppa
Dallas, TX
Posted: 02/06/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
you are wrong. you can clean most rv evaporater coils from the inside of the rv without caustic/acidic chemicals. you aren't wrong about the dirt collecting on the coil if the filter isn't used.
kellem
Shenandoah valley,VA
Posted: 02/06/20 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't remove the filter, it has a job to do.....just like your engine oil filter.
wildtoad
Blythewood, SC
Posted: 02/06/20 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, just like home systems if you run without filters the air flow will be better. One of the reasons RV furnaces don’t have them. But as mentioned you will eventually clog the cooling fins which are harder to clean than the filter.
Tom Wilds
Blythewood, SC
ScottG
Bothell Wa.
Posted: 02/06/20 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
None of my AC filters have been the least bit restrictive. To the contrary, I figure they do very little and I suspect I could read a news paper through them.
I would never take them out though, that would be a foolish mistake.
* This post was edited 02/06/20 07:05pm by ScottG *
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Monterey, CA
Posted: 02/06/20 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
No filter? Crazy bad idea. In fact I saw a video....
Guy Roan
Posted: 02/07/20 04:14am Link  |  Quote  |  Print  |  Notify Moderator
The manual says to clean the filter, so I clean it.
It is a five minute job
Guy
schlep1967
Harrisburg, PA
Posted: 02/07/20 05:00am Link  |  Quote  |  Print  |  Notify Moderator
Guy
+1 When the wife has the central vac hooked up I pull the filters and run the wand over them. One minute and they are clean.
OP If you keep taking the filters out to gain that 25% more air flow, it won't be long before you are losing 50% all the time.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Wherever I happen to park
Posted: 02/07/20 05:07am Link  |  Quote  |  Print  |  Notify Moderator
What he said times 2 Cleaning the filter.. easy
Cleaning the condenser coils.. NOT so easy.
Home is where I park it.
