RV.Net Open Roads Forum: General RVing Issues: Cleaning your AC Filter
 > Cleaning your AC Filter
ryoung
Oregon
Posted: 02/07/20 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Filters of any kind have a purpose. Use them and maintain them. Geesh.
ryoung
2018 Ram 3500 SRW Diesel
2019 Wolf Creek 840
Cummins12V98
on the road
Posted: 02/07/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
My 6 filters for my 3 AC units are a simple thin sponge type of filter media. Simply wash, squeeze dry with a towel and replace.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Hondavalk
Toledo
Posted: 02/07/20 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Cooling coils are wet. Dust in the air will quickly collect on the coils greatly reducing there efficiency. The fins will clog reducing the airflow more then the filters do.
Dave H M
IL
Posted: 02/08/20 05:02am Link  |  Quote  |  Print  |  Notify Moderator
some of that gunge may even collect on the squirrel cage vanes and further degrade the air flow. [emoticon]
BTW, I think some of us cold have cut the OP a little slack and not used the "s" word as in stupid on him.
dodge guy
Bartlett IL
Posted: 02/08/20 05:51am Link  |  Quote  |  Print  |  Notify Moderator
Look what’s on the filter when it gets used for a weekend. Now imagine it removed and what would be on the evaporator after one year of use.
Just clean the filter after every trip!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JoeH
Apollo Beach,FL
Posted: 02/08/20 06:47am Link  |  Quote  |  Print  |  Notify Moderator
I have a spare set, so I swap out the dirty with clean. Then clean and dry the dirty ones and they are ready for the next swap out
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
sayoung
Tx
Posted: 02/08/20 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Guy Roan wrote:
The manual says to clean the filter, so I clean it.
It is a five minute job
Guy
I don't clean them, just replace. The material is just a couple $ at wallyworld so I just cut 2 new ones.
campigloo
Baton Rouge, La
Posted: 02/08/20 10:56am Link  |  Quote  |  Print  |  Notify Moderator
When dust hits wet fins you get mud. Air flow will fairly quickly suffer and if prolonged will cause the compressor to run longer and hotter as well as the fan. After a while reduced air flow will cause the evaporator coil to ice over. Air don’t move through icebergs. Compressors are not cheap.
Cummins12V98
on the road
Posted: 02/08/20 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I considered that but the time it takes to rinse out from the back side and roll up to dry in a hand towel is negligible.
down home
south
Posted: 02/08/20 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
We washed our several times over time but finally the heat pump pulled part of the degraded or worn out filter up inside. Bought cheap filters and one three part very fine filtration filters for room type acs to cut up fit. Didn't work too well.CW and others didn't have any so ordered two oem types from CW?. A bit better grade and thicker items. Quieted down the heat pumps too. Most or all of the filtration occurs in one corner of the filter. I cannot understand not making the units to utilize the full filter and the grate which fits over it.
Getting tired of maintainance on every trip. So far $7,000.00. Next Coach if there is one a hard look as to quality and sevicability, including filters change...and a house filter on dash intake.
