RV.Net Open Roads Forum: Tech Issues: Best weight distribution hitch?
 > Best weight distribution hitch?
johnd123
hm
Posted: 02/10/20 10:49am Link  |  Quote  |  Print  |  Notify Moderator
reply
GT928
North Georgia
Posted: 02/11/20 06:13am Link  |  Quote  |  Print  |  Notify Moderator
I switched to the Andersen 'No-Sway' Weight Distribution Hitch a couple of years ago. It is easy to install. Pulls smooth and quiet with no noticeable sway. It is so much better than my old one. I pull a 30' travel trailer with a Jeep Grand Cherokee and I can barely tell it is back there. It may be a bit more expensive, but definitely worth in my opinion.
2011 Earthbound Golden Ridge
2013 Jeep Grand Cherokee Overland
North Georgia
camp-n-family
London, Ontario
Posted: 02/16/20 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Terryallan wrote:
Sandia Man wrote:
With enough truck to properly haul your TT around, particularly at highway speeds, any of the WD hitches with integrated sway control should suffice. Those with less than ideal towing combos, whether it is due to not enough truck or poorly designed trailers, usually resort to Hensley or Propride hitches to achieve a sense of towing comfort while underway.
On the other hand, just because you have more than enough truck does not indicate you can forego a WD/SC hitch altogether, seen too many 350/3500 trucks crawling along the highway and still see their 30' TTs excessively swaying although they are towing well below posted speed limit. Properly set-up, TTs can be towed without noticeable sway, even when passing semi-trucks.
Yep. If a person needs a super hitch to tow with. they have more problems than sway control can fix
I agree that a “super hitch” is not a bandaid to fix a poor setup but for some of us its not a matter of “need” but more of a want. If you’ve ever tried one you will want it even if you don’t need it.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
