RV.Net Open Roads Forum: wiring a 30 Amp Power Outlet 30A Circuit Breaker {{UPDATE}}
 > wiring a 30 Amp Power Outlet 30A Circuit Breaker {{UPDATE}}
Page of 6
joelyn
Az
Posted: 02/08/20 12:40am Link  |  Quote  |  Print  |  Notify Moderator
Have a 30 amp outlet next to our TT in the lot but the breaker is in the garage a distance away. so I want to install a 30amp plug with a breaker in the box also so I can shut the power off right at the box when plugging and unplugging the TT into it to save me walking a 100 ft to the breaker box...
I will be buying this box from amazon...
30 amp box and breaker
My question is does anyone have a site to show me how to wire the breaker to the outlet in the box??? checked utube but nothing that I found that shows this, only how to just wire the 30 amp outlet only....thanks
* This post was edited 02/13/20 07:54pm by joelyn *
valhalla360
No paticular place.
Posted: 02/08/20 01:15am Link  |  Quote  |  Print  |  Notify Moderator
"Features all-in-one construction for factory assured terminations"
I'm guessing, it's all wired up with the breaker already wired to the plug. There is probably a pig tail from the other side of the breaker that you have to connect up.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
joelyn
Az
Posted: 02/08/20 01:49am Link  |  Quote  |  Print  |  Notify Moderator
THAT would be great if it has that... Its amazon so nobody go really call... thanks
azrving
Oatman
Posted: 02/08/20 03:22am Link  |  Quote  |  Print  |  Notify Moderator
There are pictures of the wiring in the Amazon reviews. Your existing pvc/wire will enter the bottom of the box. Black goes to the breaker then it goes to the plug. White goes to the neutral lug and then to the plug. Green goes to the ground lug of the box then to the plug.
Right now your black wire is going to the plug. Your wire is going to the plug and your green ground is going to the plug and to the box itself. The only thing different in the new box is that the black wire will be going to the breaker then on to the plug.
Don’t count on all of the reviews as being accurate and some are dangerous. One guy suggested saving money on wire by not running a ground to the box and driving a ground rod for grounding. This is very dangerous advice.
Again, right now your wiring should be black from your existing breaker to your plug. White from your panels neutral lugs and ground from the ground lug bar. Your service panel where everything starts should be bonded which means that the neutral and ground are connected together. If you were to run any 240 volt “sub” panels off your main service they would NOT be bonded so they would run four wires. You are simply running a 120 volt circuit out to your rv, its not a sub panel. Its no different than any other wall plug in your house other than it’s heavier gauge and you are now going to be able to interrupt the black wire.
Tom_M
New Hope, MN
Posted: 02/08/20 03:35am Link  |  Quote  |  Print  |  Notify Moderator
According to pictures posted by people's reviews there is no pigtail. The box has knockouts for running wires into it. Since you will now have two 30 amp breakers in the line, either one could open if you have an overload. This is not a problem, since you are most likely using the new breaker as a shutoff. The box will work fine.
Tom
2005 Born Free 24RB
Towing 1978 VW Bug convertible
Minneapolis, MN
valhalla360
No paticular place.
Posted: 02/08/20 04:18am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, no pigtail but lugs which do basically the same thing...and actually is better.
Dave H M
IL
Posted: 02/08/20 04:33am Link  |  Quote  |  Print  |  Notify Moderator
I would think the box would have an instruction diagram in it. Order it and take a look.
All else fails, hot goes to brass, neutral to silver/chrome, and green to ground.
Don;t forget to scope things out with a volt meter before the first plug in. [emoticon]
cavie
Posted: 02/08/20 04:36am Link  |  Quote  |  Print  |  Notify Moderator
No pigtails. Black wire to the breaker. White to the panel neutral buss and ground to the ground buss. Neutral buss will be insulated from the metal can. Ground buss will have a ground screw or a lug attached to the can.
craig7h
Branson MO area
Posted: 02/08/20 04:45am Link  |  Quote  |  Print  |  Notify Moderator
That looks very close to the one I used. The female plug is pre wired, you have to wire the incoming line to the breaker part of the box. As folks have said black to the breaker, others to the grounding bar. Once you have box in hand everything will make sense.
Itasca Meridian SE 36g
Road Master Tow Dolly
midnightsadie
ohio
Posted: 02/08/20 05:29am Link  |  Quote  |  Print  |  Notify Moderator
if your not 100% sure of what your doing???? get done by somebody that does, its not hard,just has to be right. even a buddy with some electric skills.
Page of 6
