RV.Net Open Roads Forum: wiring a 30 Amp Power Outlet 30A Circuit Breaker {{UPDATE}}
 > wiring a 30 Amp Power Outlet 30A Circuit Breaker {{UPDATE}}
Page of 6
joelyn
Az
Posted: 02/13/20 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
delete
time2roll
Posted: 02/13/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Green goes in the connector similar to the Neutral.
675w Solar pictures back up
wnjj
Cornelius, Oregon
Posted: 02/13/20 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Connect the supply ground to the lug mounted on the box wall. The whole box becomes a ground connection so the green wire is fine where it’s at.
joelyn
Az
Posted: 02/13/20 09:18pm Link  |  Quote  |  Print  |  Notify Moderator
THANK U, JUST MAKING SURE..
joelyn
Az
Posted: 02/13/20 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
PERFECT, i thought that but figured i would make sure... always received the right info on many things over the many years on this forum. AGAIN, THANK U ALL FOR SHARING UR KNOWLEDGE...
Wherever I happen to park
Posted: 02/14/20 05:11am Link  |  Quote  |  Print  |  Notify Moderator
Green goes to the terminal block just above the word GREEN in the diagram
Black and white as you noted.
Home is where I park it.
Learjet
Louisiana
Posted: 02/14/20 05:13am Link  |  Quote  |  Print  |  Notify Moderator
The lug for the ground
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
sayoung
Tx
Posted: 02/14/20 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Put the green gnd wire to the lug, that's what it's for. Electrically same as the screw connection. This is considered a " sub-feed panel " which is why the white neutral has no connection to the gnd circuit.
azrving
Oatman
Posted: 02/14/20 07:32am Link  |  Quote  |  Print  |  Notify Moderator
As they said green goes to the lug that is mounted to the box. If you want to go one step further use an ohm meter or a continuity test light to check from the neutral lug to the box itself. There should be NO connection or continuity from neutral to the box. If you were to check that after its wired it would appear that there IS continuity because the neutral and ground ARE bonded (connected) at the source (main panel).
Page of 6
