RV.Net Open Roads Forum: Tech Issues: Fridge Thermistor Replacement Question UPDATE (Fixed)
 > Fridge Thermistor Replacement Question UPDATE (Fixed)
BFL13
Victoria, BC
Posted: 02/08/20 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Updated 10 Feb. and 14 Feb
My 641 Norcold cools down too cold and won't shut off. It is not in back up power--the temp light does not flash.
I have not yet fiddled with the light/thermistor to see if it is just a bad connection.
There is a replacement part available. As a temporary fix if fiddling doesn't help, can I swap out the sensor (snip the wires) and replace with an old Dometic 6 cu ft fridge's sensor (splicing in its wires to the Norcold's)
AFAIK it is all about the resistance of the sensor, but no idea what the circuit board would think.
http://rvrefrigeratorrepair.com/wp-conte........ds/2016/08/Norcold-Service-N61x-N81x.pdf
Thanks
* This post was last edited 02/14/20 09:44pm by BFL13 *   View edit history
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
cavie
Posted: 02/08/20 08:37am Link  |  Quote  |  Print  |  Notify Moderator
thermister is probably bad. google "Snip-the-the tip". Should fix your problem.
enblethen
Moses Lake, WA
Posted: 02/08/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
I would get the correct part for your Dometic. Here is one listing from Amazon for Dometic.
Dometic thermistor
Is your circuit board an original Dometic?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BFL13
Victoria, BC
Posted: 02/08/20 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Also noted the way to measure its R. Heading out so no replies for a few days.
mchero
Henniker, NH
Posted: 02/08/20 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Download the service manual.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
mbopp
Henrietta, NY, USA
Posted: 02/10/20 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Our Norcold 611V would freeze everything. A new thermistor didn't help and neither did adjusting it. The solution was to install an adjustable "optical controller board", I got the board under warranty & it was a 5-minute job to change it.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
wnjj
Cornelius, Oregon
Posted: 02/10/20 09:31am Link  |  Quote  |  Print  |  Notify Moderator
The couple of resistance charts I found showed the Norcold thermistor resistances don’t match the Dometic. So I’d say no, it won’t work to borrow an old Dometic one.
BFL13
Victoria, BC
Posted: 02/10/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it didn't work when I swapped to the old Dometic thermistor. I have not yet checked either one for R. Based on above posts, first I need to confirm the Norcold one is not right before getting a new one or one of those other gizmos.
Camping this weekend I just turned off the fridge when the fridge thermometer said it was getting too cold, and back on again later.
I am really mixed up on how the thermistor works. AFAIK they have more R when cold (at least those in-rush ones do), so that would mean the signal to turn off the fridge is when R gets that high.
But then, they say to move the thermistor up where it is warmer on the fins to make it shut off sooner. Makes no sense to me. Oh well.
http://rvrefrigeratorrepair.com/uncategorized/the-thermistor-shuffle/
BFL13
Victoria, BC
Posted: 02/10/20 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
According to this
http://bryantrv.com/docs2/docs/norcoldnxseries.pdf
At 70F it should be 11.1-12.0 kOhms. Mine is 8.2 kOhms
At 51F it should be 15.5-16.5 kOhms. Mine is 12.7 kOhms
At 70F the little Dometic one is 3.4 kOhms.
So assuming mine is out by having lower R on the whole range, then instead of shutting off the heat at 25, mine would still have been way lower so it never shut off. The little Dometic one would be even lower in R so it didn't do any good.
Perhaps my jury rig should have used both thermistors in parallel. ISTR they would add their Rs doing that. ??
Anyway, unless somebody says no, I plan to order the replacement thermistor part. I see in the manual above that it goes on the 10th fin from the right, at least to start with.
* This post was edited 02/11/20 05:41pm by BFL13 *
wnjj
Cornelius, Oregon
Posted: 02/10/20 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
The thermistors do get higher resistance when colder. As for moving it around on the fin, I think your confusion comes from interpreting their picture. The red area in the upper right is showing where you move the thermistor to make the fridge temperature follow the color (red=warmer). The upper right is also where the fin temperature is colder which in turn causes the fridge to cycle off sooner.
