RV.Net Open Roads Forum: Tech Issues: 2000 Smoke and CO Alarms
 > 2000 Smoke and CO Alarms
Moon36532
Fairhope, Alabama
Posted: 02/08/20 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
2000 Motorhome both smoke and CO alarms were attached by a permanent base with replacement inserts. Base still remain but replacement units have disappeared. I would like to continue to use the installed bases if I can recover the name and number of the replacement. No identification on bases.
Smoke insert diameter 53/8+-
CO 33/8" +-
Would appreciate help in identifying a source for replacements for these alarms
Moon Mullins
midnightsadie
ohio
Posted: 02/08/20 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
thats pretty old just buy a one with the base. after a few years the go bad any way.
Yeti plus
S.W. Ontario
Posted: 02/08/20 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
First Alert is the brand that I know of that uses a fixed base, and a removable detector unit. We have an SCO5RVA in the TC. It is a combination smoke and CO detector.
The First Alert website should give you some ideas.
Most of the other brands you just open the cover and install screws through the back plate.
Brian
2014 Chevrolet 3500 CC 4X4 Duramax, Tork Lift Tiedowns, TorkLift Fastguns, Superhitch and supertruss
2009 Jayco 213
2008 Bigfoot 25C9.4
Wherever I happen to park
Posted: 02/09/20 04:26am Link  |  Quote  |  Print  |  Notify Moderator
I changed the base.
Most of those are Atwood/kiddie by the way.. (Same product two labels)
Home is where I park it.
Moon36532
Fairhope, Alabama
Posted: 02/11/20 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Many thanks for all the help. Very useful. I found a Kidde combination alarm with the same dimensions as the legacy smoke alarm. It will install exactly over the space occupied by the old one, so will look neat.
ajriding
st clair
Posted: 02/12/20 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Aren't propane and CO monitors on the floor and smoke at the ceiling? How do you have a combo?
DrewE
Vermont
Posted: 02/12/20 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Propane is along the floor, or should be. CO doesn't really matter as CO is very very close in density to air, so diffuses pretty well throughout. Combo smoke and CO detectors are very commonly available. I in fact have two in my RV, as replacements, located where the smoke and CO detectors originally were: one in the front, and one in the bedroom area at the back.
Moon36532
Fairhope, Alabama
Posted: 02/16/20 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry for the ambiguous early post. As DrewE correctly posted,the combo monitor/alarm is a CO and smoke alarm. Yes the butane is totally separate and near the floor.
Again, thanks for the helpful suggestions as well as the questions.
