RV.Net Open Roads Forum: Tech Issues: Question about Onan Generator
 > Question about Onan Generator
Son of Norway
Denver, Colorado
Posted: 02/08/20 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Something I have never understood about generators (I have an Onan 6.5 Emerald III.) A 12-volt DC battery is used to start the generator, which then produces 120V AC. The battery supplies the energy needed to run the generator, right? So, while the generator is running, does it send a 12-volt DC current back to the battery to keep it charged, or does the generator just continue to drain the battery until the battery no longer has enough voltage to keep it running?
So if the generator drains the battery, then there must be a converter in the circuit to keep the battery charged, just like the alternator on a car engine. OK, I'm no electrical engineer, I just want to be sure that I understand this correctly.
Thanks for your tolerance on this post.
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
jdc1
Riverside, Ca
Posted: 02/08/20 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Your battery is being charged by the same converter/charger your coach is. That generator battery only starts the generator...it needs no other source to keep it running....like a lawnmower motor.
enblethen
Moses Lake, WA
Posted: 02/08/20 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it sends back a trickle of charge. Main charge comes through the converter battery charger that your coach battery is connected.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
azrving
Oatman
Posted: 02/09/20 05:13am Link  |  Quote  |  Print  |  Notify Moderator
The generator has a stator under the flywheel. It produces AC current which is sent to a regulator/rectifier. The rectifier changes the ac current to DC current which charges the DC battery. The regulator portion controls the DC voltage level to the battery.
fyrflie
Martinez, CA. USA
Posted: 02/09/20 09:37am Link  |  Quote  |  Print  |  Notify Moderator
My battery for my generator is the same battery that provides power to my coach and receives a charge from the converter/ charger when the generator is running or when plugged into 120v.
MrWizard
Traveling
Posted: 02/09/20 10:42am Link  |  Quote  |  Print  |  Notify Moderator
I think !
Everything from the 1990's up
Rv generator depend on the house converter to keep the battery charged and supply the 12v control power, fuel pump etc
And do not charge the battery
Earlier models 60s and 70's did have a 12v supply circuit as do residential models
Radiate The Happy
1997 F53 Bounder 36s
dougrainer
Carrolton, Texas
Posted: 02/09/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Gas and Diesel RV Gensets do NOT charge the starting Genset battery. They have NO built in charger. So, yes, if you do not have the system set up to charge the Genset Starter Battery it will slowly deplete the battery as it takes 12 volts to run the Genset once started. Almost ALL Gas Gensets in motorhomes are started by the Coach batteries which will be charged by the On Board Power Converter or Inverter/Charger, which ever you have, by the 120 supplied by the Genset. Doug
pnichols
The Other California
Posted: 02/09/20 11:20am Link  |  Quote  |  Print  |  Notify Moderator
I don't understand the why of your question ... and some of the responses to it.
Our motorhome's built-in Onan generator is started by power from the coach batteries ... so however the coach batteries are kept charged is also ensuring that they are kept charged up enough to always start our generator.
Aren't all motorhome (and some towables') built-in RV generator setups similar to this?
If so, of course a follow-on question of yours could be "... then how are RV coach batteries kept charged up?"
Phil, 2005 E450 Itasca Spirit 24V
wopachop
lb
Posted: 02/09/20 11:25am Link  |  Quote  |  Print  |  Notify Moderator
I was cycling my onan5500 a couple days ago. Store my batteries in the garage.
Pulled out battery to start the genny. Ran for about 55mins. Genny still running I disconnected the negative cable and it died instantly.
Also had my 12v disconnect switch turned off.
Made me wonder the dealio. If the disconnect switch was turned on, would the converter then power the fuel pump?
Will have to test that next month. The fuel bowl was filled with gas so I guess it wasnt a fuel pump issue but instead a "making spark" issue?
DrewE
Vermont
Posted: 02/09/20 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
As it died instantly, it's most likely the control board for the generator shutting it down (by killing the spark). That would be a sensible thing to happen, either specifically by design or just because it's no longer powered so ceases to operate.
The 12V system powers the fuel pump, etc. on the generator. If the battery disconnect switch is in the "use" state, and if your converter is on the house side of the switch, then it would need to be on for the generator to (indirectly) charge the battery and not have it run down from the generator's 12V consumption. If the converter is on the battery side of the disconnect switch, then of course the state of the switch doesn't matter. I guess you could say that the converter would power the generator's 12V needs, but it's just part of the 12V system and providing power into that system as a whole.
In general, there's little reason to ever have the disconnect switch disconnected that I can work out; the main one is perhaps when doing maintenance on the wiring or batteries.
(The generator's 12V connection doesn't go through the disconnect switch because it requires a lot of current to crank it; somewhere in the vicinity of 80-120A on my motorhome, if my little digital panel ammeter is to be believed.)
