RV.Net Open Roads Forum: Tech Issues: Question about Onan Generator
 > Question about Onan Generator
Wherever I happen to park
Posted: 02/12/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Onan makes many generators SOME do in face recharge the battery but the ones marked RV do not. What they do is power the hose SAME exactly as if you were on shore power so the converter recharges the battery..... I might add it also provides power to the Onan's fuel pump. The rest of the Onan is self powered.
Home is where I park it.
joebedford
Finally back home in the north
Posted: 02/13/20 08:48am Link  |  Quote  |  Print  |  Notify Moderator
If I'm on shore power, I also have my city water connection hooked up so it doesn't make sense for the generator to power the hose.
RLS7201
Posted: 02/13/20 11:06am Link  |  Quote  |  Print  |  Notify Moderator
And that folks is why we need more mental health care facilities.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Kpackpackkelley
Bryan tx
Posted: 02/15/20 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
I think it’s better for the converter to charge your batteries because if the generator has away to charge they will usually over charge your battery if you run them a long time.
deltabravo
Spokane, WA
Posted: 02/15/20 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Son of Norway wrote:
The battery supplies the energy needed to run the generator, right?
No, it only supplies power to "start" the generator.
2015 Nash 17k (bought pre-owned 5/23/18)
time2roll
Posted: 02/15/20 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Something I have never understood about generators (I have an Onan 6.5 Emerald III.) A 12-volt DC battery is used to start the generator, which then produces 120V AC. The battery supplies the energy needed to run the generator, right? So, while the generator is running, does it send a 12-volt DC current back to the battery to keep it charged, or does the generator just continue to drain the battery until the battery no longer has enough voltage to keep it running?
So if the generator drains the battery, then there must be a converter in the circuit to keep the battery charged, just like the alternator on a car engine. OK, I'm no electrical engineer, I just want to be sure that I understand this correctly.
Thanks for your tolerance on this post.
Put your meter on the battery terminals. 13.6+ volts and you are charging. 12.5 volts or less and you are not charging. Post your measurement and you will be an honorary electrical engineer.
675w Solar pictures back up
