RV.Net Open Roads Forum: Which side should rough wiring for roof ac be on?
 > Which side should rough wiring for roof ac be on?
tooldad1041
Arnold MO
Posted: 02/09/20 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
We are converting a cargo to toy hauler. We have a donor camper for the AC, fridge, windows, and couch. However the donor camper is an hour away at the lot and the cargo trailer is at the shop where we live.
We are putting the ceiling in the trailer now and can't get to the donor camper until this weekend at the earliest.
All I need to know is should the romex wire be routed to the front or the back of the AC unit? I am not sure the brand, but I'm sure it's a dometic.
I just dont want to drill through the steel trusses when I can route the wire along the wall to the correct side of the AC unit without drilling if possible.
Wherever I happen to park
Posted: 02/09/20 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
This is a guess based upon the two different makes I have but the Driver's side about 1/4 to 1/3 the way "Back" from the front.
Suggestion: Get A/C, then route wires. that way you put 'em in the right spot.
Suggestion two: Go to A/C maker's web page and shag an installation manual for your hard drive.
Home is where I park it.
ajriding
st clair
Posted: 02/09/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Always on the front on ones I have seen, mostly Dometic
Right or left does not matter as the 3-wires from AC will be kind-of looped anyway and hang in the return air space/cavity. The side that the power is attached will likely be where the knobs are located. If middle then middle, if knobs on the right then route the power there.
If you can come from the front then should be perfect, if from the side then, yes, aim at the front 5 inches.
When you say,Romex, do you mean solid copper house wire?
Generally RVers tend to believe that solid wire will be more likely to develop cracks, but the wound/stranded electrical cord (like a heavy extension cord) will not crack due to vibrations on the road.
I always buy a heavy gauge extension cord (cheaper than buying by the foot) and use that for the AC electrical. Im on 6th camper renno.
DrewE
Vermont
Posted: 02/09/20 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Nearly all commercially produced RVs use standard solid household cable ("Romex") for the AC wiring. Wire breakage doesn't seem to be a big problem. Connections working loose are more common, but would be at least as much a problem with stranded wire (for screw terminals). Stranded wire is also not compatible with the self-contained receptacles used in most RVs.
Most extension cord wire would not be approved for permanent installation per the electric code. That doesn't immediately make it unsafe, but it would make it not acceptable per code in most places.
A1RVTraveler
North Carolina
Posted: 02/09/20 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
The 120VAC wiring need to be at the front of the AC unit.
ScottG
Bothell Wa.
Posted: 02/09/20 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
Use 12awg Romex.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
tooldad1041
Arnold MO
Posted: 02/09/20 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, I am using 12g romex. Thank you for the front reply. That's all I needed to know. One of the next few weekends we will get to our lot to remove the AC from the donor and install it in the cargo.
The cargo has the frame reinforced around the vent for AC prep. I am a shop teacher. I have taught construction, electornics, and woodworking. I would use either 12g romex or 10g stranded. I chose romex as that is what is in most campers.
We have ran all wiring for 110 v outlets under trailer in 3/4 pvc with junction boxes. None exposed. All 12v wiring is 14g stranded in sheathing and ran on the inside with grommets wherever it goes through the frame to protect from damage.
All precautions are being taken for electrical. Thanks for the answers
cavie
Posted: 02/10/20 02:41am Link  |  Quote  |  Print  |  Notify Moderator
120 volt wiring in all rv/s is ROMEX. Flexable rubber cord is only used in movable slides. Wiring is per the NEC. Solide wire does not CRACK.
Just run enough wire to the hole to go all the way around it.
cavie
Posted: 02/10/20 02:43am Link  |  Quote  |  Print  |  Notify Moderator
ScottG wrote:
Use 12awg Romex.
Yes #12 GA on a 20 amp breaker.
Bobbo
Wherever I park
Posted: 02/10/20 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Just leave enough wire up there to reach either end. Cut it off if it is too long when you install the A/C.
Bobbo and Lin
