RV.Net Open Roads Forum: Which side should rough wiring for roof ac be on?
 > Which side should rough wiring for roof ac be on?
Dave H M
IL
Posted: 02/11/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
mine cones into the ac from the front of it.
Use the Bobo technique.
ajriding
st clair
Posted: 02/11/20 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Good to know solid wire should not crack. Maybe I was mis-informed, or have dated info. I have never seen cracked wire either.
Despite any code, I would not think a heavy extension cord would be more fragile than a solid wire clanking around inside an RV wall. Im not sure what the issue would be,
but it will be a lot cheaper to use house wire than expensive stranded wire…
