RV.Net Open Roads Forum: Travel Trailers: frsh water tank
 > frsh water tank
Huntindog
Phoenix AZ
Posted: 02/10/20 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
ajriding wrote:
Also, maybe the city water pressure is too high and causing the valves to leak?
A pressure regulator is a safe thing to have for these plastic water systems in RVs to protect against high city pressure.
Well the pumbing lines are PEX, which is commonly used in Houses now. TT fixtures are often cheap/poor though there is some good stuff being used.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2011 Silverado CC DA big dually.
Bobbo
Wherever I park
Posted: 02/10/20 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
The PEX, itself, can take the pressure. It is the fittings connecting the PEX together that poses the risk from high pressure.
Bobbo and Lin
poppa
Dallas, TX
Posted: 02/11/20 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
thanks for all the replies. first time out on new tt. I used the hose end regulator, just noticed the tank filled. don't really want that but don't really want to use pump if I don't have to. the valve on the discharge mite be the trick, or a better check valve. thanks!
allen8106
Burrton. KS
Posted: 02/13/20 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Some rigs have a valve at the pump to shut off suction from the tank when on city water. If that valve is open it can back fill the tank. My 2010 Jayco is set up that way.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 20
shaner82
Ontario
Posted: 02/16/20 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Mine shows full the second I connect to city water. It has since it was brand new. The tank is empty one second and shows full the next, so I don't believe it's backflowing into the tank.
kellem
Shenandoah valley,VA
Posted: 02/17/20 11:41am Link  |  Quote  |  Print  |  Notify Moderator
This is also a thought as my previous trailer did the same......empty tank read full apon city hookup.
GrandpaKip
Flat Rock
Posted: 02/18/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Then the question becomes why is this happening?
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
poppa
Dallas, TX
Posted: 02/18/20 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
update. I either had water in the tank or the check didn't check the first time but last wknd it was empty when I hooked up to water and didn't fill, was empty when I disconnected.
 > frsh water tank
