RV.Net Open Roads Forum: General RVing Issues: Insurance Denying Claims
 > Insurance Denying Claims
Page of 5
T18skyguy
Eugene, OR
Posted: 02/10/20 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Just wondering if you took it off road. I read an article by an RV engineer who mentioned that RV's are designed for on road use only. I hope something works out for you.
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. Between rigs right now.. Wife and daughter. Four cats which we must obey.
colliehauler
Mc Pherson KS USA
Posted: 02/10/20 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
Insurance companies don't cover structural defects. Just like your car motor fails and needs replaced that would not be covered. All this should be in your insurance policy of what they cover and what they do not. If you have a extended warranty on the unit it should be covered.
* This post was edited 02/10/20 05:43pm by colliehauler *
schlep1967
Harrisburg, PA
Posted: 02/11/20 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Yep, like others have said you seem to be confusing the term "insurance" with "extended warranty".
I managed to get lucky and insurance did cover water damage for me. Long Story...
After taking delivery of my new trailer, bringing it home and parking it for a few months, when getting ready to use it I checked the tire pressures. When checking I found one of the tires was "C" rated and the others were "D" rated. Called the manufacturer and they sent me a complete rim and tire for replacement. Fast forward two years. Suddenly have a soft spot in the floor right behind the location that had the "wrong" tire in place. Take it to an RV repair place and there is no leak from the top. It seems when the unit was being towed in from Indiana, it must have blown the original tire and tore things open underneath the trailer. Towing in rain blew water up into the floor where it eventually rotted the floor out.
The insurance company tried the "It's a water leak and you didn't do proper maintenance" argument. I fought back with photo's of the underside of the trailer where the leak was and letters from the manufacturer saying there should be no routine maintenance of that area.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
colliehauler
Mc Pherson KS USA
Posted: 02/11/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
What happened to the OP?
Dave H M
IL
Posted: 02/11/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] maybe the OP did not like most of the answers.
jdc1
Rescue, Ca
Posted: 02/11/20 09:09am Link  |  Quote  |  Print  |  Notify Moderator
4x4van wrote:
You are describing a warranty issue, not an insurance issue. And since your trailer is 8 years old, you're out of luck unless you somehow have an extended warranty/service contract. Even then, the fine print will likely not go in your favor.
BINGO!
JIMNLIN
Oklahoma
Posted: 02/11/20 09:25am Link  |  Quote  |  Print  |  Notify Moderator
The sidewall outside skin cracking at the slide bottom has/was a issue with many 5th wheel trailers even back as far as my '97 trailer.
Mine started cracking at the front corner. From the corner it worked down at slight angle. Drill stop the crack didn't help. Finally dropped by my rv dealer for their input. Service mgr gave me a 18" foot long piece of flat plastic molding.
I cut the skin all the way down (13") and sealed the crack with a sealer...then installed the molding with a sealer with two SS button head scrws over the crack. That was in '03/'04 and its never leaked.
Everyone noticed many 5ers came from the factory with flat piece of molding over that same place. I assume the factory cut the skin so it would stay under the molding.
My trailer had no frame stress issues.
dodge guy
Bartlett IL
Posted: 02/11/20 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the front is flexing! This is common on 5th wheels that were built poorly. Not much you can do other than seal it up and check on why it’s flexing! I’m guessing the 5th wheel area was made with the wrong metal. Might want to do a search of this kind of failure.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
ReneeG
Meridian, Idaho
Posted: 02/11/20 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a site with resource information - RVTravel Resources
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Bobbo
Wherever I park
Posted: 02/11/20 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
He has a grand total of 1 post to his name. My guess is looking for another forum to validate his desires.
Bobbo and Lin
Page of 5
