RV.Net Open Roads Forum: Med. travel trailer with bed and "living area @ oppsite ends
 > Med. travel trailer with bed and "living area @ oppsite ends
tmckenna
Long Island
Posted: 02/11/20 07:36am Link  |  Quote  |  Print  |  Notify Moderator
thomasmnile wrote:
I believe any manufacturer that offers
a rear living floorplan will fill the bill. We owned a Jayco WhiteHawk 27 DSRL. 2013 model with a single slide that contained the dinette and sofa. Front bedroom separated from living area by the bath and kitchen. The overall length bumper to tongue was 31' 6", the actual box was 27'. A great couples trailer that could accommodate the occasional grandchild.
Jayco still builds the floorplan but in 2019 renamed it 28RL.
I don't love the rear living floor plans because the majority of the seating is across from the kitchen area, would prefer it to "compartmentalized" more from front to back, rather than mixing the kitchen area with the living area.
WayneAt63044
St. Louis, MO
Posted: 02/11/20 08:12am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2013 Forest River V-Cross Vibe 26VFK that might fit your needs if you can find a used one. We, too, wanted private access to the bathroom from either of 2 sleeping areas. The door from the rear short queen is solid and slides. The bath is over the axles and is separated from the center dinette/living area with a solid hinged door. The dinette is curb side and opposed on the street side by a slide out that contains a sofa/inflatable mattress bed. Kitchen is in the front. Gross weight is 7,800 lbs and we have towed it all over the US including mountains with our 2009 Ram 1500 Hemi Quad cab 4x2 with 3.92 gears. There is a door between the living area and rear bedroom which bypasses the bathroom. We leave it permanently closed and on the bedroom side filled the space with a wardrobe and on the living side built a bench across the doorway with a place to sit or pile something along with storage bins below.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
thomasmnile
Lake Mary, FL
Posted: 02/11/20 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Not sure you will find what you seek in an under 30' trailer, the size is the limiting factor. Happy hunting.
tmckenna
Long Island
Posted: 02/11/20 08:40am Link  |  Quote  |  Print  |  Notify Moderator
That one is actually really nice, I like the fact that it has 2 slides, especially one being in the bedroom. Only thing thats iffy for me is the secondary sleeping arrangements being between the master bedroom and the kitchen. Its not a deal breaker, just a personal preference honestly.
WayneAt63044
St. Louis, MO
Posted: 02/11/20 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Single slide in the living area. No slide in the bedroom.
Gdetrailer
PA
Posted: 02/11/20 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
deltabravo wrote:
Outdoors RV TimberRidge 24RLS or 24RKS, but I'd want a 3/4 truck to tow them, and probably a diesel. They are heavy.
Ouch, those whales are also longer than the OP asked for at 28' 8" tongue to rear ladder.. Which re-enforces that the OP NEEDs to expand into a longer trailer to find what they are asking for.
Quite heavy to boot at advertised 6650 lbs empty and dry hitch of 795 lbs (any any seasoned RV owner knows the advertised dry weight is typically a bogus number and the actual dry weight will be heavier).
Found info HERE
Gdetrailer
PA
Posted: 02/11/20 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Something else to take into consideration, having the "bath" functions in the middle of the RV means one side of the trailer will be cut off from the other when bathroom is "occupied"..
Or in some cases the Lavatory sink will be outside the toilet or shower area in order to not cut off passage from front to rear.
This is typical and can't be avoided with having the bath in the middle..
Personally, I have no issue walking a few extra feet to get to the bathroom in the middle of the night, yes, it requires me to pass by the couch/bed, but to give those sleeping on that bed some "privacy" we added a curtain at that area they can pull closed..
After all, you ARE "camping" and with camping one must make a few concessions..
tmckenna
Long Island
Posted: 02/13/20 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Most of the layouts I've been looking at have dual entry so both areas are accessible even if the bathroom is occupied, and the older Skyline Layton I was looking at has the walkway between the kitchen and bathroom so both living areas are accessible while the bathroom is in use.
