RV.Net Open Roads Forum: Travel Trailers: Towing 20' camper with Jeep Liberty
 > Towing 20' camper with Jeep Liberty
dodge guy
Bartlett IL
Posted: 02/12/20 09:29am Link  |  Quote  |  Print  |  Notify Moderator
Naturist has it right. No need for a massive truck to pull the trailer. 2500lbs dry will be around 3500 lbs max loaded for a trip. Use a quality WD hitch with built in sway control. The 3.7 has more than enough power for that size trailer. Yes it’s wheelbase is short, but so is the trailer. The ratio would be similar to a 1/2 ton crew cab short bed and a 32ft TT! Which works just fine.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JKJavelin
Milwaukee, WI
Posted: 02/12/20 09:31am Link  |  Quote  |  Print  |  Notify Moderator
There's a YouTube channel called Slim Potatohead and he tows an Aliner A-Frame trailer with a Jeep Liberty. Check him out, maybe ask him about it. He just got a new trailer but hasn't revealed it on his channel yet, but he's a minimalist so it's gonna be small. By the way, he makes very interesting videos.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS--Now with Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 22 Nights
GrandpaKip
Flat Rock
Posted: 02/12/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
An Andersen Hitch would be perfect for weight distribution on this setup.
You do need to find the payload rating for the Jeep. It’s on the tire sticker on the door jamb. It says something like, Total Cargo shall not exceed xxxx pounds. This number helps you set up the whole shebang.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
the bear II
Torrance CA.
Posted: 02/12/20 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
As you can see from the replies there is only one reply from someone who has actually towed a similar setup with a Jeep Liberty. Based on that reply it seems you will be OK provided your hitch is setup and your weight in the trailer is distributed properly.
mcadaman
Posted: 02/12/20 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Total carg should not exceed 950 lbs.
Jebby14
Windsor Ontario
Posted: 02/12/20 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
950- weight of everyone and everything in the vehicle - weight of hitch.
950
-100 (hitch)
-500 (cargo in jeep, guessing very sorry if im wrong)
=350 lbs of tongue weight.
350/0.13 = 2692 lbs fully loaded.
if I guessed at numbers right id say you don't have enough payload. do the math with your numbers and remember even empty your trailer will be well above its magical dry weight.
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
mcadaman
Posted: 02/12/20 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for all the useful knowledge. This small unit is just what we've been looking for. We didn't want a big trailer, just something that we can use for getaway weekends. We're getting older and want to get out of the tent.
Monterey, CA
Posted: 02/13/20 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Such a difference between my 2015 Tahoe and my 2020 Silverado 1500...long wheelbase equals stability.
RollTideCamp
Tuscaloosa
Posted: 02/13/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
mcadaman
Congrats to you on joining the RVing community!!
I remember enjoying this post I think you may as well :
Towing with our 2006 Jeep Liberty CRD (turbodiesel)
mcadaman
Posted: 02/13/20 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks RollTide. I'll check it out.
