RV.Net Open Roads Forum: Travel Trailers: Towing 20' camper with Jeep Liberty
 > Towing 20' camper with Jeep Liberty
mcadaman
Posted: 02/14/20 06:43am Link  |  Quote  |  Print  |  Notify Moderator
I'm putting on an electric brake controller also. I keep hearing about WDH but I don't know if it's needed.
Jebby14
Windsor Ontario
Posted: 02/14/20 07:12am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't touch that setup without a good weight distributing hitch and sway control. the best sway control you can afford given the short wheelbase of the liberty
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
GrandpaKip
Flat Rock
Posted: 02/14/20 07:53am Link  |  Quote  |  Print  |  Notify Moderator
You will absolutely want to have a WDH. Andersen would be a great fit.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
K-9 HANDLER
Maryland's Eastern Shore
Posted: 02/14/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
naturist wrote:
The OP especially asked for input from folks actually towing with a Libby. I am such a person. Until it dropped a valve at 200,000 miles, I towed a 21 foot overall, 5,000 lb gross weight, 3680 lb dry weight TT with a 2005 Liberty. Mine was the 2.8 liter 4 cylinder diesel, rather than a gas V6. It towed just fine.
I dragged that trailer from Virginia to Seattle, down to LA, then back to Virginia. A couple years later, I dragged that same trailer from Virginia through Denver to Las Vegas, then in a circle around the Grand Canyon back to Vegas, before returning to Virginia.
I can tell you that I found it very helpful to use a WDH and to tow in AWD (aka “full time 4 wheel drive). Those two made it very directionally stable. I understand the OP’s Libby is 2wd, so AWD isn’t an option. I can’t comment on the gas engine, but the diesel did have a tendency to overheat, crossing mountains in the summer, so that even though it had the pull to keep up with traffic, it definitely could have used a much better cooling system.
Most of the time I had a wife and 80 lb dog in the Jeep, too. It had the payload capacity, not a problem.
Like
Camping near home at Assateague National Seashore with our wild four legged friends
