RV.Net Open Roads Forum: Travel Trailers: Fresh water tank drain valve issue
 > Fresh water tank drain valve issue
ER Alaska
Alaska
Posted: 02/12/20 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
I think most if not all RV tanks are just a single wall tank. The fact that you are finding a hose makes it seem that the valve is mounted remotely from the tank. On my trailer the valve is mounted under the side where it is easily accessible. There is a tube behind the valve that disappears back through the corrugated plastic underbody and then over to the actual tank. Since it sounds like you cannot see the actual tank I would start figuring out how to get the underbody down so you can see what you are dealing with.
Right you are. Posted my post and then saw that you'd already provided the answer.
ppine
Northern Nevada
Posted: 02/12/20 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
Same problem on a 2013 Rockwood. Easy fix. Buy a new valve.
