RV.Net Open Roads Forum: Class A Motorhomes: Stated wheelbase
 > Stated wheelbase
purplekeenah
greensburg, pa
Posted: 02/12/20 06:03am Link  |  Quote  |  Print  |  Notify Moderator
When reading the specs. for a coach that has a tag-axle, is the stated wheelbase measurement from the front axle to the rear axle, or to the tag-axle?
I'm considering a newer rig with a tag and have to consider the length of my parking pad.
2007 Newmar Ventana 3936
330 Cummins
2013 Chevy Equinox
MountainAir05
New Mexico
Posted: 02/12/20 08:32am Link  |  Quote  |  Print  |  Notify Moderator
When you pay a toll they measure from the center hub on the steer and the center hub on the tag. If you want another way is from the center hub front to the center between the rear axle and the tag.
Or center hub rear to center hub tag, the free space between the rear tires.
I just use the the front to the tag. A lot easier.
purplekeenah
greensburg, pa
Posted: 02/12/20 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
MountainAir5, thanks for the reply. So basically you're not aware of any standard that mfgs. adhere to when reporting the wheelbase for any of the tag axle rigs they produce.
MountainAir05
New Mexico
Posted: 02/12/20 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Look at this one. I have seen older unit that were over weight before you purchase them. Some of the newer ones that puts in everything a person thinks they must have also go over. just look at the weight of the rV and go to the state you want to travel their roads and you might get shocked. With a tag your max will be close to 45 and even maybe a 43. Our last RV had tag and was 43. Just look at the spec for length for the brand you are looking at.
https://oversize.io/regulations/axle-weight-calculator
purplekeenah
greensburg, pa
Posted: 02/12/20 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
My original post may have been misleading. I'm looking at a rig on the internet, aside from many photos there also is a spec sheet that identifies the wheelbase is 288".
Is the 288" the distance from the front wheel hub to the rear wheel hub, or, is it the distance from the front wheel hub to the tag axle hub?
MountainAir05
New Mexico
Posted: 02/12/20 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
I think you will have to measure the unit. Just looking at say Newmar Mountainaire, you can get a 40 and 45 foot with tag. Depends on what you order. I can not tell you what you would get for the 288 inch wheel base. Just measure from front axle to the rear or tag if it has one. I would say the tag. Probable not the answer you are looking for.
MountainAir05
New Mexico
Posted: 02/13/20 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Better stated than what I stated.
https://en.wikipedia.org/wiki/Wheelbase
Just measure what you have when its park on your slab and see where the 288 lands.
purplekeenah
greensburg, pa
Posted: 02/13/20 08:48am Link  |  Quote  |  Print  |  Notify Moderator
MountainAir05, thanks for info.
Blaster Man
Posted: 02/13/20 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
This is how Freightliner does it....other's do it to the center of the dually wheels and the tag and others to it to the center of the tag:
On trucks with multiple rear axles, wheelbase is generally measured from the center of the front hub to the center of the hub of the most rearward drive axle.
2014 American Eagle
chuckftboy
Fleming Island, Florida
Posted: 02/13/20 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Wheel base is center front wheel to enter drive axle on my chassis
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
 > Stated wheelbase
