RV.Net Open Roads Forum: Unsuccessfully trying to upgrade my exhaust brake
 > Unsuccessfully trying to upgrade my exhaust brake
shoalsgary
northwest Alabama
Posted: 02/12/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2003 Holiday Rambler Endeavor with Cummins CAPS engine and my exhaust brake is frozen. I've tried soaking in diesel fuel, soaking in PB Blaster, using Bigger Hammer, heat, and NOTHING frees it up. So I want to upgrade to the PPRXRB brake. But every supplier wants the model number of my brake. The only number on my pump is C319 cast into it, but that doesn't satisfy them. Where can I find the model number of my original brake???
wolfe10
Posted: 02/12/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Have you contacted PacBrake: https://pacbrake.com/contact-pacbrake/
Have your engine serial number handy.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
shoalsgary
northwest Alabama
Posted: 02/12/20 09:20am Link  |  Quote  |  Print  |  Notify Moderator
can't find engine serial number
MrWizard
Traveling
Posted: 02/12/20 10:31am Link  |  Quote  |  Print  |  Notify Moderator
I the Cummins i had
The engine serial # was on a metal tag
Irrc it was near the injection pump
Radiate The Happy
1997 F53 Bounder 36s
ScottG
Bothell Wa.
Posted: 02/12/20 11:03am Link  |  Quote  |  Print  |  Notify Moderator
I think you'll find the S/N tag mounted sideways on the timing cover, kind of behind the inj. pump.
You can use this number to contact Cummins and they can tell you every part that's associated with your eng.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
schlep1967
Harrisburg, PA
Posted: 02/12/20 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Is it frozen because of carbon build-up? Or is it a mechanical issue? If it is carbon build-up try soaking it in Purple Power overnight. $8 a gallon at our local Autozone. Works great for cleaning all things EGR related.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
shoalsgary
northwest Alabama
Posted: 02/12/20 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
nO CARBON BUILD UP. PROBABLY FROZEN FROM NON-USE.
shoalsgary
northwest Alabama
Posted: 02/13/20 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Now I'm trying to find the PXRB that replaces it. I provided my engine number (46248452) and have found nothing on the exhaust brake, original OR PXRB.
wolfe10
Posted: 02/13/20 07:10am Link  |  Quote  |  Print  |  Notify Moderator
You talked with PacBrake Corp?
keefr
Edmonton
Posted: 02/13/20 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Is it possible that your original was made by Jacobs (the Jake people)? They supplied exhaust brakes for some engines of that vintage. I agree with Brett Wolfe, you should be contacting PacBrake directly - they will be able to tell you what part you need better than any dealer or reseller. I have found them to be incredibly helpful.
Never argue with an idiot - they drag you down to their level and beat you with experience. - George Carlin
