RV.Net Open Roads Forum: Class A Motorhomes: lost 12VDC in coach
 > lost 12VDC in coach
calvin5445
seattle
Posted: 02/12/20 10:24am Link  |  Quote  |  Print  |  Notify Moderator
I have suddenly lost all the 12vdc in coach,Ac is fine, rear 12vdc fuse box is dead, any idea's!
Calvin Graedel
1989 Monaco Crown Royale
Matt_Colie
Southeast Michigan
Posted: 02/12/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
How long have you had this coach?
Does it have a "Salesman Switch near the door?
Start checking from the house battery to the fuse panel.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
midnightsadie
ohio
Posted: 02/12/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
get your volt meter out start at the battery.
joelc
Cedar Point, NC
Posted: 02/12/20 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Usually there is a in-line fuse after the battery. Mine was hidden. Follow the 12V line. Should be with-in 2-3 feet of the battery. Also, if you have a shut off switch check to see if that is on. It might have been moved.
parkmanaa
Houston, Tx.
Posted: 02/12/20 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like your AC to DC converter has a problem.
Need to check to see if AC (120v) is getting to one side of converter,
and if so, check to see if DC (12v) is getting out of he other side.
jdc1
Riverside, Ca
Posted: 02/12/20 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
Or, it could be a bad ground.
Wherever I happen to park
Posted: 02/12/20 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
My first tool choice is a 12 volt automotive test light
Brigth = Good
Dark = bad
Dim also bad
Problem exists between Bright and Not Bright
Start with clip any non-painted metal part near battery tip to battery Positive Bright good. Move out along the positive wire to the other end of the wire connected to the battery... Same test. .NOTE.. when you move the ground clip. if possible re-test the last known good spot (Testing ground)
No light on the first test move ground clip to battery - If bright bad ground cable
You come to a box with 2 bolts and wires attached. test all HEAVY wires if there are both heavy and small wires that is your cut off solenoid.
Home is where I park it.
pianotuna
Regina, SK, Canada
Posted: 02/12/20 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
There often is an automatic circuit breaker between the battery bank and the 12 dc distribution center. It may have failed.
Regards, Don
myface
Posted: 02/13/20 06:15am Link  |  Quote  |  Print  |  Notify Moderator
When I lost power, took me some time with help, to find- hidden under dashboard- 40A breaker.
mike brez
Unknown
Posted: 02/13/20 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
When mine did that it was the 200 amp fuse
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
