RV.Net Open Roads Forum: Class A Motorhomes: slideouts not working
 > slideouts not working
jgraham429A
florida
Posted: 02/12/20 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2001 Damon Challenger equiped with a power gear slideout system for 2 slideouts. Both slideouts stopped working and looking at the manual they operate off of the coach batteries. I had to pull the batteries out, but assumed the slideouts would still work. Is the fact that the coach batteries are not hooked up the problem? any suggestions what to look for would be appreciated. I am connected to electricity
Yankee Clipper
Cairo, GA
Posted: 02/12/20 11:13am Link  |  Quote  |  Print  |  Notify Moderator
For my system, the PowerGear motors require that the coach be level, the batteries have at least 12.4 volts, and the engine be operating. Also, check your battery storage switch of ON or USE.
HTH
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, Duke the overgrown Boxer mascot/lousy watch dog
Rosey the minidachshund resident Princess-in-Chief
jgraham429A
florida
Posted: 02/12/20 11:32am Link  |  Quote  |  Print  |  Notify Moderator
thanks Yankee Clipper. The RV is level, but there are physically no batteries. I checked the battery connect/disconnect switch and started the unit, but still no success
way2roll
Wilmington NC
Posted: 02/12/20 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Mystery solved. No coach batteries, no power to the slides.
jdc1
Riverside, Ca
Posted: 02/12/20 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Yep...it completes the curcuit. Even a dead battery would make it work
ppine
Northern Nevada
Posted: 02/12/20 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Even a partially charged battery may not work. Power up your rig and the slideouts should work.
Sam Spade
North Central Florida
Posted: 02/13/20 06:00am Link  |  Quote  |  Print  |  Notify Moderator
What ?? Where do you think the power would come from with no batteries present ?
BAD assumption.
Yes, that is your problem.
NOTE: With my Damon, the slides are locked out when the engine is running.....meaning they won't move on purpose.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
jgraham429A
florida
Posted: 02/13/20 06:53am Link  |  Quote  |  Print  |  Notify Moderator
you know my son told me just to take an old car battery and hook it up and probably completing the circuit would make it work. thanks everybody for your help.
Sam Spade
Posted: 02/13/20 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
Well THAT is bad advice too.
YOu need a healthy supply of 12 VDC to open the slides.
The only 2 ways you can get that is with a healthy battery OR if you are plugged into shore power.
Note the previous comment about the slides being disabled while the engine is running.
