RV.Net Open Roads Forum: Tech Issues: Sinarek closet. Slide
 > Sinarek closet. Slide
Terry 25
Hagerstown, MD
Posted: 02/12/20 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds normal. Goes out 2 inches and stops. Other large slide worked. Tried repeatedly. Same result. Fuses good. Checked carefully for obstructions but is c!ear. What else can I check. Thanks
2016 F-250 Gas
2015 Rockwood 2608WS
Corkey05
Washington State
Posted: 02/12/20 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
Could be a low voltage issue. Check (and clean) all your connections and pay special attention to the ground connection.
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
azdryheat
Tucson, AZ
Posted: 02/12/20 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
What's a Sinarek closet?
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
beemerphile1
Ohio
Posted: 02/13/20 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe Schwintek?
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
joebedford
Sheltering at home
Posted: 02/13/20 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming you mean Schwintek (I've never heard of the thing you tyoed) you can use the manual override to bring out the slide.
However, it sounds like you have some kind of obstruction.
TUCQUALA
Kennewick, WA
Posted: 02/13/20 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
As prev stated, probably Schwintek (Lippert) slide. If the closet walls on the outside have channels top and bottom with cut gears, it is a Schwintek.
Schwintek-In-Wall slideout doesn't have manual override, only way is to remove motors to move slide. BUT, there are some procedures to try. Here is a link to the manual, with info on resetting the control unit you can try. Need to know where the control unit is in your trailer!!
https://lci-support-doc.s3.amazonaws.com/manuals/slideouts/ccd_0001602.pdf
One thing you might try quickly is to hold the switch till the motors stop when retracting. You'll hear them hit the amp limit. Supposed to resynch the motors. You should do same anytime slide is run in our out. Hold switch for a bit after the slide opens and stops and same when closing. May not be the solution, but simple try. If not, you'll need to spend time in the manual!!!
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
bid_time
Michigan
Posted: 02/14/20 05:26am Link  |  Quote  |  Print  |  Notify Moderator
Schwintek DOES have a manual override, Check on page 5.
Clicky
TUCQUALA
Kennewick, WA
Posted: 02/14/20 10:34am Link  |  Quote  |  Print  |  Notify Moderator
OK, picky people, let's qualify the "manual" override!!! It's an "electronic manual override"!!!! Great nomenclature. BUT, it is NOT a mechanical way of operating the slide. If it doesn't work, ya gotta disengage the motors. Nowhere else in the mechanics to "manually"
operate the slide.
bid_time
Michigan
Posted: 02/14/20 10:58am Link  |  Quote  |  Print  |  Notify Moderator
operate the slide.
Would you also like to "qualify" the statement that the "only way is to remove the motors to move the slide"...; you can simply unplug them at the controller?
fj12ryder
Platte City, MO
Posted: 02/14/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
bid_time wrote:
operate the slide.
To be fair, I've read through the manual and it specifically mentions removing the motors before trying to move the slide. I didn't see anywhere that it said the slide could be moved with the motor simply unplugged. That appeared to be a safety step prior to removing the motor.
And, honestly, everyone is operating under the assumption that the OP was referring to Schwintek, since no one has ever heard of a "Sinarek" although the spelling certainly isn't that similar. Maybe the OP could stop by and comment.
Howard and Peggy
"Don't Panic"
