RV.Net Open Roads Forum: Travel Trailers: TT television
 > TT television
kellem
Shenandoah valley,VA
Posted: 02/13/20 05:11am Link  |  Quote  |  Print  |  Notify Moderator
Cheap is sometimes more expensive.
Went through 2 Element TV's in 1 year.
RoyB
King George, VA
Posted: 02/13/20 05:40am Link  |  Quote  |  Print  |  Notify Moderator
I picked up a 24-inch VIZIO from WALMART for my OFF-ROAD POPUP trailer operations. This was more than enough size wise for what we needed for the small floor plan of our off-road POPUP trailer.
I found one that still used the 120VAC ADAPTER BLOCK that plugged into a DC connection port on the back of the VIZIO TV set. This allowed me to either use 120VAC using the adapter or the DC Voltage from the battery setup plugging directly into the TV set. This was a few years back and I found a DC Adapter cord plug from Radio Shack that fit the VIZIO DC port.
Without finding a TV SET that has a DC POWER PORT you will have to use a small PURE SINE WAVE POWER Converter to run the TV directly from your Trailer battery when camping off-grid... My 24-inch VIZIO fit in place of this small TV set I was originally using..
roy's image
I use the standard Winegard Batwing antenna up on a portable TV mast that I can install in minutes when setting up... Works great for us camping off-grid...
Roy's image
If you always just use camp ground sites that has 120VAC Pedestals than this is no issue for you. Just get a TV set that plugs into 120VAC.
Roy Ken
* This post was edited 02/13/20 06:08am by RoyB *
CA Traveler
The Western States
Posted: 02/13/20 09:21am Link  |  Quote  |  Print  |  Notify Moderator
schlep1967 wrote:
My biggest problem was that the shape of the televisions has changed. I had a large, almost square inset that the original TV filled. I matched the width with the new one and still had open space in the top one third of the opening.
Those dinosaurs are fading rapidly. You'll enjoy the much improved TV quality. Add shelves or cabinet doors above the new TV or otherwise modify the entire opening.
2014 Grand Cherokee Overland
Bob
2oldman
Ca
You don't have to get a cheap one. Better ones will work too.
CA Traveler
The Western States
Posted: 02/13/20 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Think outside the box - errr opening. Repourpose the opening and mount the new/larger TV on a swingout in front of the opening or elsewhere.
allen8106
Burrton. KS
Posted: 02/13/20 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure the TV has the correct bolt pattern for your TV mount. There are a couple different standards depending on size.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 20
DarkSkySeeker
Freestone, California
Posted: 02/13/20 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Johno02 wrote:
go to walmart and get the cheapest one that fits. It will work for the next ten years...
Agreed (are we up to 4X now?)
I recall the RV salesman suggesting they could install a special RV rugged TV. That was before I knew much about anything RV-wise. Now, years later, I am glad I just put in one that a friend gave to me that was sitting around in his garage unused.
There is something special about camping in an RV.
campigloo
Baton Rouge, La
Posted: 02/13/20 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
We like our 12v. Works when we’re boondocking or if the park power goes out. It’s a 32” and only uses @ 40w.
Ron3rd
Upland, CA USA
Posted: 02/13/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Buy what you like. Nothing magical about TVs in an RV.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
philh
Belleville MI
Posted: 02/13/20 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
smart TV to stream (not off campground wifi)
 > TT television
