RV.Net Open Roads Forum: Fifth-Wheels: Load Range G Tires
 > Load Range G Tires
Page of 7
CoMoCo
Oakville, ON, Canada
Posted: 02/13/20 08:45am Link  |  Quote  |  Print  |  Notify Moderator
I currently have Goodyear G614 tires on our fifth wheel (see signature). This is what came on the trailer when we bought it new in 2013. I am looking at new tires and am trying to understand why the G614 tires (235/85R16) have a diameter of 30.7 inches whereas all other 235/85R16 tires have a diameter of 31.7 inches.
If I switch tire brands I don't know if a 1 inch larger tire will fit in my wheel wells.
Does anyone know why the Goodyear G614 tires have a smaller diameter than every other tire brand? Even the Goodyear Endurance 235/85R16 has a diameter of 31.7 inches. (I have no intention of dropping to an E range tire - the Endurance is just an example).
Thanks for any input.
'15 GMC Denali 3500 DRW D/A; '13 Lifestyle 36FW
jdc1
Riverside, Ca
Posted: 02/13/20 08:59am Link  |  Quote  |  Print  |  Notify Moderator
I'll bet it's a typo error.
B.O. Plenty
Minnesota
Posted: 02/13/20 09:01am Link  |  Quote  |  Print  |  Notify Moderator
One inch more in diameter if that is correct, will only be 1/2" taller. Not a concern at all.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Bipeflier
Centralia, MO
Posted: 02/13/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
I just ran out and quickly (it is 6 degrees F) measured mine. They are slightly less than 31". I replaced my China Bombs with the G614s and really didn't notice any difference in the stance or clearance in the wheel wells. I'm betting anything will fit in yours.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
MFL
Midwest
Posted: 02/13/20 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Most cases 3"s of clearance will work. I would not go to only 2"s, or less though.
Jerry
ependydad
Here and there
Posted: 02/13/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
You likely have less of an issue above the tire as you may have issues between the 2 tires on each axle.
On my old camper, I had less than 2" of space between the tires. When I wanted to upgrade them, I had to be very particular about what I replaced them with because I couldn't afford any kind of outer diameter change.
And yes, I saw a good 1" deviation on load range E tires.
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
fj12ryder
Platte City, MO
Posted: 02/13/20 10:38am Link  |  Quote  |  Print  |  Notify Moderator
If trailer tires are anything like motorcycle tires, there will be a size variance between manufacturers, with the same tire size.
But if you are considering Sailun tires, they come in a 235/80-16,which is, I believe, the same size as the Goodyear, as well as the 235/85-16.
Howard and Peggy
"Don't Panic"
CoMoCo
Posted: 02/13/20 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. I think the size is right - GoodYear has been publishing the same diameter for at last 8 years. Doesn't mean it's right though.
The Sailun 235/80-16 is an option I am considering.
blofgren
Surrey, B.C.
Posted: 02/13/20 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
My Sailun S637's are going on 5 years old, still look like new, and only lose 2-3 psi each even when sitting for 6 months over the winter. I would go with them again without hesitation, and they were close to half the price of the Goodyears.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
Cummins12V98
on the road
Posted: 02/14/20 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Curious have the GY's given you any problems?
If not then I guess it's down to $$$ and either US or Chinese Made.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Page of 7
