RV.Net Open Roads Forum: Class A Motorhomes: Rear chf f53
Coach Cleats
Watertown, Ct
Posted: 02/13/20 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Should the jacks be retracted or down when doing the REAR chf and any suggestions or tricks to the fix I should know about in advance?
2004 Safari Cheetah 36 PDD, 03 Wrangler Sahara Toad W/Buddy Brake.
Denise and Bob 70 Years as Teachers!
Kodi D'dog'.
About to play as long as we worked.
Senior Softball! What a blast. Nothing is routine!
Blackdiamond
So. Cal
Posted: 02/13/20 10:25am Link  |  Quote  |  Print  |  Notify Moderator
doesn't matter, only if you want some extra room to work under there.
03' Fleetwood Southwind 32VS
Enclosed Trailer hauling the toys
05 525 EXC KTM
15' FE350s Husqvarna/KTM
07 Rhino, long travel, 4 seater
Executive
Posted: 02/13/20 10:58am Link  |  Quote  |  Print  |  Notify Moderator
You already asked this once.
LINK
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Morro Bay, CA
Posted: 02/13/20 11:54am Link  |  Quote  |  Print  |  Notify Moderator
"You already asked this once"...yesterday.
Coach Cleats
Watertown, Ct
Posted: 02/13/20 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
My first request refered to the front CHF. The most resent was for the rear CHF.Thank you for your helpful advice.
way2roll
Wilmington NC
Posted: 02/13/20 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Answer is the same - no jacks. I personally wouldn't get under an RV with the jacks down, understanding that the tires should save you if they let go, but the jacks might lift it up enough for you to get your hand or anything else somewhere that if the jacks were to let loose, you could loose whatever is stuck in that gap. No thanks and no need. Never mind the fact that the jacks will drop the wheels and make the job harder not easier. There's enough space and if fairly level, just reverse the z brackets and done. KISS method on this one.
Dutch_12078
Winters south, summers north
Posted: 02/13/20 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Raising the coach with the jacks will make it easier to do the work, but I do suggest using jack stands or cribbing as a safety measure. As long as the coach is raised evenly, there will be no more stress on the sway bay than there would be not raised up. The bar just pivots in its bushings.
Dutch
2001 GBM Landau 34' Class A
Morro Bay, CA
Posted: 02/13/20 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
2/12 post does not say “front.”
It said “Is it better/easier to do the CHF with jacks down or retracted?”
* This post was edited 02/13/20 07:42pm by Lwiddis *
