RV.Net Open Roads Forum: Class A Motorhomes: Class A, gas or diesel
 > Class A, gas or diesel
Bumpyroad
Virginia
Posted: 02/14/20 05:07am Link  |  Quote  |  Print  |  Notify Moderator
ego sells a lot of diesels, more so than need. and unless you buy a prevost, you are not top drawer anyhow.
bumpy
Gjac
Milford, CT
Posted: 02/14/20 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I would figure out where you want to camp, FHU CG's or more secluded NFS, SP, or COE type Cg's. If you want FHU's go with a 40 ft DP, if more secluded a 35 ft Gas would be better. How much storage do you need for the stuff you want to carry? How heavy will your tow vehicle be? Also understand a shorter gas MH with 362 HP will weigh 1/2 of what a 40 ft DP weighs with the same or less HP. Some people like RV resorts and some like boondocking in remote areas, having owned a toyhauler and 5th wheel you should have a pretty good idea of your preferred camping style.
janstey58
Glenwood, IA
Posted: 02/14/20 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Bill_Satellite wrote:
When diesel cost $0.60 to $1.00 more per gallon you won't make up the difference in fuel economy.
Actually my old gasser MPG was between 4-7 MPG, and my current diesel is very consistent 10 MPG regardless of hills/wind, etc... And diesel is currently 25 cents higher than gas in my area, so I think I am ahead currently on fuel cost with my DP.
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
oldave
Tx
Posted: 02/14/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
We have owned both as well .
I feel the most noticeable difference is noise and ride .
We can ride along in relative quietness and talk with out yelling .
We also still use our in motion satellite tv and can actually hear it
You may be expecting to much out of an exhaust brake , it may not
perform any better than the braking effect of a gas rig , after all
the diesel rig is usually quite a bit heaver .
The more expensive coaches will have an engine brake ( compression )
now that is a real brake , it's what the semis have .
Performance of gas rigs of recent yrs is much better than the old
carburetor engines so don't assume the diesel will out perform it
Diesel coaches drive and just feel different , a little slower revving up
and air brakes feel different too
You probably should drive several of each and see which suits you .
Leonandlisa
Las Vegas
Posted: 02/14/20 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Thanks again everyone for your replies, it has given me input as well as some other things to consider as we look around. Anything we do won’t be cheap, so just want to make sure we considered everything before we buy something.
Bill.Satellite
Full-timer
Posted: 02/14/20 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Great! Good for you. That's not the norm. I was talking about the average. If you leave "your area" you may be unpleasantly surprised by the difference. Here in GA gas is $2.07 and diesel is $2.67. In CA expect to see $3.10 vs. $3.60+.
Glad you are in a diesel bubble market but that's not the norm. If you don't believe me, download Gas Buddy and take a look around.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
Big Katuna
Deland, FL
Posted: 02/14/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
MPG is a red herring. If one only drives 3000-5000 a year , the difference in fuels costs between one RV and another are inconsequential.
My Kharma ran over my Dogma.
ppine
Northern Nevada
Posted: 02/15/20 08:24am Link  |  Quote  |  Print  |  Notify Moderator
I would rather have a used diesel than a new gas engine rig.
On the West Coast diesel costs less than regular unleaded gas.
ppine
Northern Nevada
Posted: 02/15/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
bumpy
Performance and longevity are what sells most diesels. Economy sells some of them.
mike brez
Unknown
Posted: 02/15/20 08:50am Link  |  Quote  |  Print  |  Notify Moderator
20 years of gas and 5 for diesel hands down the diesel.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
