RV.Net Open Roads Forum: Fifth-Wheels: front cap fading and peelinag
 > front cap fading and peelinag
Rich&Mar
wa usa
Posted: 02/13/20 11:53am Link  |  Quote  |  Print  |  Notify Moderator
I know this has been discussed before and that it is a common problem. My cap looks bad, peeling and fading. It is a 2011 cougar fiver with the smoke gray color. Looking for ideas from others who have done something and the appx cost. Are rv mfg painting the caps now? And how are they holding up?
rich
ford truck guy
Pennsylvania
Posted: 02/13/20 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
The best, permanent fix is to strip it, paint it, clear coat it...
I don't think they are ALL offering painted caps yet on to many TT's, only a few are i believe.. That is a question that needs to be asked when buying a new RV..
I had that happen to my 1998 Holiday, when replacing it that was the first question i had when looking at RV shows...
* This post was edited 02/13/20 04:25pm by ford truck guy *
Me-Her-the kids
2015 Ford F350 SD 6.7
2020Redwood 3991RD Garnet
ppine
Northern Nevada
Posted: 02/13/20 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Paint it.
ScottG
Bothell Wa.
Posted: 02/13/20 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Had mine repainted after I removed graphics. It cost me $800 for a 2 part epoxy paint job.
It was gorgeous and much tougher than the orig gelcoat junk.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
B.O. Plenty
Minnesota
Posted: 02/13/20 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
They never were painted so there is nothing to strip except the decals. It is colored gelcoat and it fades. You can buff and polish all day and it will come back. A large truck/equipment refinishing shop will have a large enough paintbooth. I got quotes from $800. to $3500. to do mine.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Veebyes
Posted: 02/14/20 05:41am Link  |  Quote  |  Print  |  Notify Moderator
One of the things that RVs & boats have in common is gel coat. A rule that applies to boats applies to RVs also. Both can be any colour you like as long as it is a shade of white. Perhaps more so with RVs than boats. RV builders, in their efforts to cut costs & weight, seem to start with a much thinner gel coat layer than boat builders.
The only options an RV owner has with a colour is much more frequent maintenance or paint with a clearcoat.
2007 Alpenlite 34RLR
GTO66
Posted: 02/14/20 09:29am Link  |  Quote  |  Print  |  Notify Moderator
I had a wrap placed on mine as after twenty years buffing and polish just wasn't cutting any more. The cost on mine, which is a TC was about seven hundred.
Lightning55
Pleasanton, CA
Posted: 02/15/20 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Mine faded out after 18 months and Jayco repainted and clearcoated it under factory warranty. I heard it was at a cost of about $1800. If mine ever does it again, I'm thinking about a "wrap" instead of painting. Way cheaper, looks good, and might last longer.
Veebyes
Posted: 02/15/20 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
A wrap might be a solution, particularly if a quality material is used.
When the factory decals deteriorated after about 5-6 years we had this made by a sign shop from a picture we had taken. Why advertise a defunct RV builder? It is a little on the small side but the largest material the sign shop had at the time.
The important thing is that it has been there over 3 years with absolutely no fading.
[image]Click For Full-Size Image.
We have something unique. You simply will not see another front cap like that anywhere. This for a couple hundred.
