RV.Net Open Roads Forum: Tech Issues: inverter advice
 > inverter advice
twor
CA
Posted: 02/13/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Replacing a Xantrex 400W with similar size inverter. Recommended brand to get?
I have 4 Trojans for house batteries.
Ron3rd
Upland, CA USA
Posted: 02/13/20 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Xantrex is known for making good inverters. Samlex pro series and Morningstar are good brands too. You want something quiet. The cheap inverters have loud non thermo controlled fans that run constantly.
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
Wherever I happen to park
Posted: 02/13/20 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
I will second Ron you might even consider an inverter upgrade to power more you have enough battery to feed up to about a 2000 watt and nuke lunch.
Home is where I park it.
Near Annett’s Mono Village, Bridgeport, CA
Posted: 02/13/20 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn’t inverter efficiency peak when the unit is operating close to its max? If that’s true, buying a larger inverter than necessary wastes power. See this article and chart:
https://www.solarquotes.com.au/blog/two-reasons-you-must-look-at-efficiency-curves-when-choosing-your-solar-inverter/
3 tons
NV.
Posted: 02/13/20 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
X2, a ProWatt 2000w sine-wave is a good match for most microwaves...
Posted: 02/13/20 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
OP didn’t mention microwave. He’s been ok with 400 watts.
time2roll
Posted: 02/13/20 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend the GoPower 300 watt sine wave inverter. Very low idle draw and a provision to add a remote switch.
675w Solar pictures back up
Ullagone
Dallas, Texas
Posted: 02/13/20 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
I also recommend Xantrex, they are a reliable brand.
allen8106
Burrton. KS
Posted: 02/14/20 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Magnum or Samlex in that order.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 36
NicodemusY
New York
Posted: 02/15/20 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like we have the same inverter set up , my 400 watt unit had been replaced by a previous owner with a xantrex SW 600. It's been working great for the 5+ years I've used the coach. Looks like the replacement would have taken a half hour at most. It's all the inverted power I need, right now. No charge function required.
If I install a residential fridge , I would up grade.
 > inverter advice
