RV.Net Open Roads Forum: Towing: WDH Questions
Search only in Towing
Open Roads Forum  >  Towing
 > WDH Questions
bjkb1f
Missouri
Posted: 02/13/20 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
I took my truck and TT to the CAT scales and have a few questions about the number. Hoping you guys can help.
TV is a 2018 F150
TT is an Alpha Wolf 26DBH
I know my TT is just about as big as you’d want to go with a half ton. So I want to make sure I load it correctly.
Unloaded truck wt - Front: 3120 Rear: 2520
Coupled with no WD: Front: 2680 Rear: 3960 Trailer: 5540
Coupled with WD: Front: 2920 Rear: 3640 Trailer: 5640
TT weight: 6540 loaded but with empty tanks
Based on my math, my tongue weight is right at 1,000 lbs - coupled/no WD weight on truck minus unloaded truck weight. That is the correct way to calculate this right?
Second, it looks like the hitch is only putting about 100 lbs of the tongue weight back on the trailer axles.
Third, I’m still not back to my unloaded weight on the front truck axle.
I assume I should adjust the hitch a bit more to get more weight distribution. Is that correct? My front wheel well distances are within the recommended range but it’s still about a half inch higher when hitched with WD than unloaded.
My plan is to move some of our **** to the rear storage compartment and adjust the hitch to get the tongue weight closer to 13% (right now it’s just over 15%) and further distribute the weight to the front and trailer axles.
I’m below all weight limits (axles, tires, hitch) but getting close on payload so I’d like a little more wiggle room.
Thoughts?
* This post was edited 02/13/20 03:52pm by bjkb1f *
troubledwaters
Potomac
Posted: 02/13/20 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing says you have to restore all the weight back on the front. You've restored over 50%, if your GVWR if greater than 6640 I'd say you're good to go.
BarneyS
S.E. Lower Michigan
Posted: 02/13/20 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Were it me, I would adjust to try to get the front truck axle as close to unloaded weight as possible and always had comfortable towing. That is the way I have done it for years and have never had a problem. I fully realize that is not what some manufacturers recommend but I want my headlight aim to be normal and not blinding other drivers at night, and I want my truck to handle just about like normal. A half inch at the front wheel well may well translate to several feet high down the road at night.
That is not what some manufacturers recommend however so do what you think is best for you. I cannot say that you should do as I do because each situation is a bit different. The size or strength of your WD bars, the size and strength of the trailers A frame, the type hitch etc. all contribute to the decision.
I would recommend that you read what your truck manufacturer says, read what other members here say, and then make up your mind on whether to add more WD to your hitch. Good luck. [emoticon]
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
Bobbo
Wherever I park
Posted: 02/13/20 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
What does your tow vehicle owner's manual say? My Ford says to measure the front fender height from the pavement before attaching the trailer. Measure it again after raising the tongue jack. Use a WDH to put 50% of the difference back on the front end.
Bobbo, Linda and the furry kid (45 pound rescue)
Mike134
Elgin
Posted: 02/13/20 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have a '19 F150 pulling a TT with GVWR of 7500 lbs. I put all but 40 lbs back into the front axle when setting up my WDH. Works for me.
lawrosa
Horry County
Posted: 02/13/20 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
I put as much weight back on the front to restore to original as I can. And with my WD hitch and both trailers I owned thats tilting the head back with max washerers installed and chain to 9th link on mine from the bars.
All WD are different but with that much weight I would tilt the head as far as you can...
what WD hitch you have?
see towing planner here.
http://towingplanner.com/ActualWeights/T........&w2da=3960&w2ta=5540&w3sa=3120&w3da=2520
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
Posted: 02/14/20 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Numbers, down to the pound are semi meaningless.
You're well within the capabilities of the truck.
How does it handle? Does it "feel" like the front end is light?
Does it feel like you need more off the rear axle of the truck?
If the answers are no, then you're dialed in.
If yes, then crank the wdh up a bit more.
bjkb1f
Missouri
Posted: 02/14/20 09:07am Link  |  Quote  |  Print  |  Notify Moderator
WDH is a Fastway E2. No chains, but it does use washers to tilt the hitch head. I was using 6 when I weighed it and will be adding more to get more weight distribution.
The front wheel well distance is about half way back to original. I’ll try another washer or two and see what that does.
Terryallan
Foothills NC
Posted: 02/14/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
I do agree with Barney. I get my front as close to unhooked weight, and height as I can. On link will make a big difference.
But the real question is. how does it drive. when turning the steering wheel, does the steering seem light, or too easy? If it feels too easy. You will have sway. If it feels normal. you should be ok.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Boomerweps
Hills of PA
Posted: 02/14/20 11:07am Link  |  Quote  |  Print  |  Notify Moderator
While the front wheel well height changes are the key measurements, the other are also very important. What is the loaded, unloaded, and WDH applied wheel well heights?
If you return the front wheel well height to half or less with the WDH, great. BUT, if your rear is squatting down, it increases your TV angle front to back.
I also measure the height of the TT box frame front to back and side to side. I want my TT within an inch or so level for towing.
IMHO, the WDH should try to transfer the weight across the TV & TT and make them all push down on the suspensions.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
 > WDH Questions
