RV.Net Open Roads Forum: Class A Motorhomes: LEDs Replacement for Flourscent
 > LEDs Replacement for Flourscent
down home
south
Posted: 02/14/20 01:07am Link  |  Quote  |  Print  |  Notify Moderator
Amazon has three plug an play or direct replacement 12 in bulbs for rvs etc. or 21.00. five watts 500 lumens plus a few other listings including those you have to eliminate the ballast to use.
The three bulbs for 21.00 is not cheap in my world but the 32.oo for one is certainly high. Direct replacement is what I like.
Anyone used these or better direct replacement LEDs for 12 in florescents?
craig7h
Branson MO area
Posted: 02/14/20 03:43am Link  |  Quote  |  Print  |  Notify Moderator
I can not speak about the 12" replacements. I did however replace my stick house 48" ones with leds. They were direct replacement, very happy with them.
Itasca Meridian SE 36g
Road Master Tow Dolly
Wherever I happen to park
Posted: 02/14/20 05:22am Link  |  Quote  |  Print  |  Notify Moderator
There are two types of LED replacements. One is a "plug and play" and for RV's I actually DO NOT recommend these
The other you can strip the "Ballast" (really an inverter) out of the fixture and there are 12 volt leads on the tube you connect up instead. NICE and the advantages go beyond just the LED upgrade
What I did
Amazon has some reels of leds (5 meter long strips) for I think about 8-9 bucks.
I stripped the ballast and sockets out of the fixture
Sliced and diced the 5 meter strip into fixture length strips
Soldered on jumpers and leads.
NICE. But if you don't know how to work on electronics this is NOT a method for you.
Home is where I park it.
Flute Man
Payson, Arizona
Posted: 02/14/20 05:56am Link  |  Quote  |  Print  |  Notify Moderator
I upgraded mine several years ago and replaced fluorescents with 18 inch LEDs which cost about $20 each. It was easy to remove the ballast and hook up the12v direct.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
SpeakEasy
Western New York
Posted: 02/14/20 06:23am Link  |  Quote  |  Print  |  Notify Moderator
for what its worth....
I start out that way because my experience is in the sticks and bricks, not the RV.
I replaced 12 of the 4-foot flourescents with the LED's where you bypass the ballasts. One of the best home upgrades I've done. It's a very easy install, so don't shy away from this method if you're concerned about it.
One thing I'd wonder about in an RV installation is the effect of the shake-rattle-and-roll on the bulbs. I'm not saying it would be a problem; but it's something I'd want to find out about.
I also learned that Lowes will let you bring in old flourescent bulbs for safe disposal.
-Speak
It's just Mrs. SpeakEasy and me now (empty-nesters). But we can choose from among 7 grandchildren to drag along with us!
2014 F-150 Super Crew Short Bed 3.5L Ecoboost
2014 Flagstaff Micro Lite 23LB
Bruce Brown
Northern NY
Posted: 02/14/20 07:16am Link  |  Quote  |  Print  |  Notify Moderator
I too did the $5.00 roll of LED strip light with the new ends. Pretty simple and easy. I keep a roll in the MH and when a light goes out I switch it over.
We did a new kitchen a few years back, I did the same for under cabinet lights. $100 vs $1500. The contractor had never seen it done that way, that's how he's doing them now.
I did my daughter and S-I-L kitchen the same way.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
opnspaces
San Diego Ca
Posted: 02/14/20 09:56am Link  |  Quote  |  Print  |  Notify Moderator
What powers the under cabinet lights? Do they have one of those cheap LED remote control units or are they hard wired somehow to a switch?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
down home
south
Posted: 02/14/20 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
I was looking at 12" tubes. For whatever reason I thought that was what I had.
What I do have are 18" tubes and there are fewer plug and play offerings, that I see so far. 13 yo 16.00 each.
If I use plug and lay i can use either Flourescent or led and won't have to rewire if I decide to switch back or can't fnd led on shrt notice.
dalenoel
S.E. Michigan
Posted: 02/14/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
I took the ballasts out and put in 4 strips per 12" fixture. We now have plenty of light and a lot less power usage. Very simple route to success.
03 Monaco 36PBD DP - 06 Malibu Maxx Toad (SOLD) 18 Focus Toad
08 Jayco Eagle 322FKS (SOLD)
Wife and myself, Lutheran Deacon, Oreo the Malshi, and maybe a grandkid or two
Bikeboy57
Inverness, FL
Posted: 02/14/20 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Downhome
You are missing the point. The rv style flourescent is horribly inefficient because it changes 12 volt dc to high voltage ac to power the florescent Putting the plug and play in the existing fixture does nothing to reduce power consumption. Nothing. The other posters have given you good info on how to do it inexpensively and result in the energy savings
Richard and Rhonda
1999 Newell
Subaru Outback toad
