RV.Net Open Roads Forum: Truck Campers: Front Hitch receiver F-250
 > Front Hitch receiver F-250
time2retire
Pittsburgh
Posted: 02/14/20 05:11am Link  |  Quote  |  Print  |  Notify Moderator
I am looking at putting a Curt front hitch receiver on my 2008 F-250 super duty.
From my previous beach buggy life in the 80's I still have a Hamburger's (Pt. Pleasant, NJ) custom made aluminum cooler/rod holder rack. I had 2 square receiver tubes welded to the front frame of my truck for easy attachment and removal.
Instead of welding new receivers on my F-250 I was thinking about just buying a Curt, 500 lb. capacity front hitch receiver. 4 bolts to the frame and it's on.
The thing I am worried about is the sway and give with a single attachment point. Is the hitch receiver snug and tight with the different implements you can use with it?
* This post was edited 02/14/20 05:31am by time2retire *
MFL
Midwest
Posted: 02/14/20 05:51am Link  |  Quote  |  Print  |  Notify Moderator
I've never had a receiver that fit snugly with the draw bar, and many implements/ramps/carriers will be quite loose. There are holding devices to use that will snug up/tighten this issue, some better than others. It will likely never be as solid as using two receivers, but depends a lot on what you haul.
Jerry
Buzzcut1
Norcal
Posted: 02/14/20 06:20am Link  |  Quote  |  Print  |  Notify Moderator
They make a locking hitch pin that is threaded, a spring loaded nut fits inside the tube of whatever you are going to insert into the receiver. I use them and no sway at atl to the tray or bike rack
https://www.etrailer.com/Hitch-Locks/Let........qO-Lj30w7pXHlW6MxikTPSVmkLhoCKhwQAvD_BwE
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
NRALIFR
Truck Camping Out West
Posted: 02/14/20 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Add some stabilizing turnbuckles from the tow loops to the outside corners of the front rack like this. It will be rock solid then.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
VoodooMedicineMan
Illinois
Posted: 02/14/20 07:49am Link  |  Quote  |  Print  |  Notify Moderator
I have a 05 F 350 dually diesel and I had a hitch mounted where the fog lights used to be. I bought one ofthese to carry the 500 Harley I have.
Bill and Joey the dog
Kayteg1
California > Nevada
Posted: 02/14/20 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Not sure what year body style changed, but I had front hitch on 2006 F350 and it was mounted under tow hooks, so easy job and worked quite well.
For 2017 the hitch is mounted under the frame, so quite a task to fish all the bolts and than not only required removal (or cutting) lower trimm, but hitch scrapes steep driveways, or high curbs. I use it for short platform with generator and have to pay attention where I drive.
In the past, I used rear hitch on motorhome for PWC carrying, so I added 2 more receivers on the sides with additional bars.
That not only stop any rocking of 500 lb PWC, but added security.
time2retire
Pittsburgh
Posted: 02/14/20 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Great info guys. I had thought about the turnbuckles and that's what I'll try first. The lock nut will be plan B. Thanks
Rick
NRALIFR
Posted: 02/14/20 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Try to find some turnbuckles with a forged body, rather than the aluminum body in my picture. Those eventually stripped out and I replaced them with some that are more heavy duty.
jaycocreek
Idaho
Posted: 02/14/20 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Looking at a front receiver for my truck,I noticed both Curt and Draw Tite had tow hooks on the hitch, which would make it easy to snug it down as pictured above with turnbuckles...
Assuming your Curt hitch your looking at does not..
1994 F-350 DRW /460/k&n intake /415# torque/lance 9.6/3 gr 27 batteries/Honda 2k/Honda 3K/Reese solid bar extension/buddy heater/3 inverters/3/4" Horse mat cushion-Non slip/happi Jack tie downs /Firestone bags /Yamaha Rhino/Winch/locker UTV/Zieman trailer
time2retire
Pittsburgh
Posted: 02/14/20 11:59am Link  |  Quote  |  Print  |  Notify Moderator
I think attaching the the turnbuckles to the tow hitch defeats the purpose of stabilizing the implement. Wouldn't you want the hooks attached to the truck?
