RV.Net Open Roads Forum: Toy Haulers: Electrical help
Search only in Toy Haulers
 > Electrical help
ThePrez
AZ
Posted: 02/16/20 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2014 Sandsport 25FBX. Cannot find any real information on it which is how
I stumbled upon this website. Owned it for a few years with no real problems other than typical maintenance. Recently noticed my batteries were **** near dead which I thought was odd as it’s ALWAYS plugged in. GFI outlet that trailer is plugged into was tripped. Ok no big deal, I reset. Tripped again. After doing this 4 or 5 times my wife noticed sparks coming out of fuse panel next to fridge under sink. No breakers are tripped. No fuses are blown. There is a piece of hardware underneath that is wired into breaker and has burn marks on it where is sparking. What is this thing and what does it do? Obviously has something to do with batteries charging and fridge.
Any ideas or advice? I don’t know how to post pics on this off my iPhone.
Thanks Prez
Kern County, CA
Posted: 02/16/20 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
“as it’s ALWAYS plugged in.”
How often do you check the battery water level? Solar is safer way to charge and maintain batteries.
Try this for pictures... http://photoposting.is-great.net/?i=3
enblethen
Moses Lake, WA
Posted: 02/16/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
It could be a GFI circuit breaker. Or an arc fault breaker.
What color is wire?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Posted: 02/16/20 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Can you turn that one breaker off that has the device with burn marks? Maybe the rest can operate normal. Does this breaker have any identification of usage?
In the mean time get a portable charger direct on the battery as it is desperate for a charge. If spending money get at least 5 amp charger, 20 amps is better.
Does that burnt devise have any name, description, or numbers on it?
675w Solar pictures back up
enblethen
Moses Lake, WA
Posted: 02/16/20 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
If itis either a gfci or arc device, it may need to be removed to clear issue.
opnspaces
San Diego Ca
Posted: 02/16/20 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
It might be your arc reactor going out. [emoticon]I would flip the breaker that it is connected to an see if the GFCI still trips. If all is well with the breaker off then look for a name or number on the unit that sparks and we'll see if we can help.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
joebedford
on vacation from rv.net
Posted: 02/16/20 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
Is that your converter and it's shorting out?
ScottG
Bothell Wa.
Posted: 02/16/20 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a simple loose connection. I would start by tightening every screw terminal.
Every RV I've bought had some loose connections at the breakers.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
cavie
Posted: 02/16/20 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
There are no arc fault breakers in an RV. There are no GFI breakers unless in a higher end MH. GFI Outlets are used in the RV world. It would be in the bathroom. Pictures would help. 2 GFI's in series don't play nice.
ScottG
Bothell Wa.
Posted: 02/16/20 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
All good advice but GFCI's in series have no effect on each other. You could have thousands of them in a string and they would all work fine.
Cheers,
Scott
 > Electrical help
