RV.Net Open Roads Forum: Toy Haulers: Electrical help
Search only in Toy Haulers
 > Electrical help
cavie
Posted: 02/16/20 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Not so. Some do, some don't. Many RV'ers had discovered this problem. I proved it for myself with 2 of my trailers parked side by side. 2002 5th wheel and 2011 Keystone. Neither would work when plugged into a GFI circuit. Trip the GFI outlet in either trailer and the shore GFI would stay activated. It seams to be within the quality if the GFI outlets.
cavie
Posted: 02/17/20 03:28am Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
It might be your arc reactor going out. [emoticon]I would flip the breaker that it is connected to an see if the GFCI still trips. If all is well with the breaker off then look for a name or number on the unit that sparks and we'll see if we can help.
Please tell me what an "Arc reactor" is! FYI RV's do not use Arc Fault breakers.
ThePrez
AZ
Posted: 02/17/20 04:34am Link  |  Quote  |  Print  |  Notify Moderator
No I do not check water levels in my batteries. They are sealed gel batteries (x2) and my trailer does not have an inverter. This “hardware” looks like a big chip board. One side has green and white wires going to breaker #2 marked “general” other side of board has red and white wires, thick gauge going to a bus bar looks like. If I flip the #2 breaker off than it doesn’t spark as there is no power obviously. But my fridge tv and batteries are receiving no power. This is not an issue of being plugged into a gfi. Had no problem the last 4 years. No name or branding on chip board other than some numbers. Punched them in google and didn’t find much. Let me figure out this photo bucket ****. Who woulda thought the 30 yr old is struggling with photos lol
* This post was edited 02/17/20 05:12am by ThePrez *
ThePrez
AZ
Posted: 02/17/20 05:11am Link  |  Quote  |  Print  |  Notify Moderator
Numbers on unit are
AC04W138607996
Whatever it is power is traveling from cord (either direct plug in or generator) going through this circuit board deal and traveling out the other end to batteries fridge and tv? Ac microwave and everything else is unaffected
ThePrez
AZ
Posted: 02/17/20 05:15am Link  |  Quote  |  Print  |  Notify Moderator
ThePrez
AZ
Posted: 02/17/20 05:27am Link  |  Quote  |  Print  |  Notify Moderator
I get off work at 3 I’ll post some better pics. Thanks for your help guys. I really appreciate it!
Prez
enblethen
Moses Lake, WA
Posted: 02/17/20 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Looks to be the circuit board for the converter. Battery charger.
looks a lot like this. Not sure about your numbers.
Circuit board
Look on the enclosure fore make and model of converter.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
deltabravo
Spokane, WA
Posted: 02/17/20 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Power going to that board simply supplies power to the converter (battery charger).
That board shouldn't act as a pass through for power to other circuits.
It's likely that the breaker supplying power to the converter also supplies power to the fridge and the TV.
RV manufacturers are famous for running multiple devices on the same circuit breaker.
I touch on that subject in this video where I move the converter to its own breaker.
2015 Nash 17k (bought pre-owned 5/23/18)
joebedford
on vacation from rv.net
Posted: 02/17/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
joebedford
Posted: 02/17/20 07:34am Link  |  Quote  |  Print  |  Notify Moderator
ThePrez wrote:
Like I said in an earlier post, your converter is toast and that's why your battery is dead and why you fridge doesn't work (it needs 12V).
 > Electrical help
