RV.Net Open Roads Forum: Fifth-Wheels: getting trapped inside a park
 > getting trapped inside a park
Page of 6
ppine
Northern Nevada
Posted: 02/20/20 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
Could be time for a smaller rig.
padredw
East Texas
Posted: 02/20/20 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Almost -- twice.
About ten years ago in California, Valley Center, Woods Valley campground. This time my fault: one wrong turn took me into a portion of the campground with no exit for my 34' fifth-wheel. Fortunately residents of that area stopped me just before point of no return and helped me to back out--long way!
Two years later, Stone State Park near Sioux City, Iowa. Had reservations but found no campsite adequate, proceeded to a loop at the end of the campground--loop too small and tight with a small tree right in the center. Took much hemming and hawing but I did just barely get out. Went on to a KOA across the river in South Dakota. Finally did get a refund because there was no one on duty to assist me at the state park.
These are the campground close calls. Many others on the road. Once near Brandon, MS went to visit a friend in a retirement center pulling the fifth-wheel (on the way to Florida). No parking at all, but I turned down the residential street across from it. It turned out to be a cul de sac. It was a narrow street with mailboxes at driveways. Would not want to do that again. Almost destroyed a mailbox and had to back into a very busy boulevard.
A thread like this excites us all and brings back memories mostly of narrow escapes which are our victories.
strikeu
Bama
Posted: 02/20/20 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
garyp4951 wrote:
My Gps took me to the 9th Ward in New Orleans, and I did a few blocks of backing to get out of there quick.
one of the best investments I made was a truckers GPS, enter weight, height and size all around and if properly updated will keep you off narrow streets, one ways, bridges, etc..the one I have runs about $400 but well worth it.
2018 RAM 3500 DRW 6.7L Cummins (daily driver RAM 2500 same engine)
2017 Forest River Crusader
1 wife, 2 Cats
Fly Navy
ford truck guy
Pennsylvania
Posted: 02/20/20 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
It happened to me once, pulled into a park only to find out the gate was stuck and no way to turn around... I backed it out onto the street and went down the highway to the next CG
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
magic43
Brookhaven, Ms.
Posted: 02/20/20 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
A GPS will get you in trouble big time. If something does not seem right, STOP, because it's probably not right.
I often take a walk through a campground following my expected path to be sure that all is OK.
magic43
Fisher Bill
Tigard
Posted: 02/20/20 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
And if you choose not to decide you still have made a choice...
gbopp wrote:
You can check out any time you like,
But you can never leave.
Someone should make a song with that phrase. [emoticon]
2006 Chevy 3500 Dually 6.6 Duramax Diesel & Allison Transmission
2010 Northshore 28RK by Dutchmen
Our first fifth wheel!!!
strikeu
Bama
Posted: 02/20/20 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
padredw wrote:
Almost -- twice.
my opinion is that state parks are the WORST. most of the state parks are much older than the current generation of campers. used to be a small pop-up or tent camping--which a lot of people do and enjoy-- then comes along (maybe since the late 70s?) 30+ ft trailers and tow rig combos well over 60 ft and you quickly mark state parks off your list. I don't think the funding is there to make them any different...no all, but most.
troubledwaters
Potomac
Posted: 02/20/20 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
My truck has a reverse gear in it. They beauty of that is you can go out the same way you got in. I use that gear frequently.
jfkmk
NJ
Posted: 02/20/20 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I was on a trip for work a year after Katrina and heading back to the airport from Chalmette. My gps took me through the 9th ward to a closed bridge, and I had to backtrack to the main road. Lovely area.
BarabooBob
Baraboo, WI
Posted: 02/20/20 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Peninsula State Park in Door County Wisconsin has a turn around at the entrance that is impossible for anything longer than a 20 ft trailer. If you pull in and for some reason decide to leave, you have to drive into the park quite a way to get turned around. If you go against the instructions that are posted at the turn around, you will hit either a large rock or a tree. I have seen it often. One time I watched a tow truck skid a 5r sideways to get it out of the turn.
If you go into the park about a half mile, there is a nice turn around.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
Page of 6
