RV.Net Open Roads Forum: Beginning RVing: New generator for new rv. Recommendations
 > New generator for new rv. Recommendations
Page of 7
ronharmless
The far side
Posted: 01/28/21 07:34am Link  |  Quote  |  Print  |  Notify Moderator
So you push your views off on other people, even though are doing things within the prescribed bounds, and if they don't accept your views for themselves, then you "label" them.
So who made you the police of all things civil and uncivil Karen?
Lantley
Ellicott City, Maryland
Posted: 01/28/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
It's really not that complicated. The idea of treating others they way you want to be treated goes back to biblical times, long before trendy "Karen vernacular came about.
My view is I don't want to hear your genset plain and simple. When we get down to ME attitude I want you to extend the same courtesy to ME.
If you are going to be camping around ME I want you to use a quiet inverter genset. Because then YOU will be doing all you can not to disturb ME. I will do the same.
If you are using a non inverter, loud open frame genset you are not even trying not to disturb ME. With a loud non inverter genset you are using a cheaper genset that is not suited for camping around others.
You are choosing to take the savings at my expense.
The money you save is at the expense MY peace and quiet.
The true silence purist have ditched their gensets altogether and are using batteries with inverters and solar charging to achieve zero noise.
They have made large investments in their equipment in an effort not to disturb anyone with generator noise.
They did it not because it was legally mandated, although one day it maybe.
They did it because they want to enjoy nature and their camping experience in its purist form with out any man made background noise.
If you truly want to be a ME only guy. I suggest you buy yourself a large plot of land that you can control and be as loud as you want.
However if you are camping on public land or land that you don't own or control, I suggest you consider how your actions impact those around you.
Refer back to the golden rule and treat others the way you wish to be treated and everyone can have an enjoyable experience
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
nickthehunter
Southgate, MI
Posted: 01/28/21 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Deleted
JalynRohan
Posted: 02/08/21 02:08am Link  |  Quote  |  Print  |  Notify Moderator
gbopp wrote:
Congrats and welcome to the forum.
Tell us about your RV, make/model etc. and what you want to run with the generator. It will help us give you a more accurate answer.
You generally cannot run several appliances at the same time with a 2000 watt generator.
Enjoy your travels.
Which RV do I need to buy for a family of 5?
https://www.generator-review.com/
JalynRohan
Posted: 02/08/21 02:12am Link  |  Quote  |  Print  |  Notify Moderator
Enjoy your travels.
I already have a Champion 3400 RV ready generator. Does it sufficient while traveling?
Dutch_12078
Winters south, summers north
Posted: 02/08/21 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Just to put a number on the noise issue, The National Park Service has this rule:
"Under this section the following is prohibited: Operating motorized equipment or machinery that exceeds a noise level of 60 decibels measured on the A-weighted scale at 50 feet, or, if below that level, nevertheless makes noise that is unreasonable."
36 CFR Section 2.12
Dutch
2001 GBM Landau 34' Class A
pianotuna
Regina, SK, Canada
Posted: 02/08/21 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. But if you wish to run it while traveling I'd suggest a cage or at minimum a rack with a hardened steel cable.
Regards, Don
AE5TE
NEW MEXICO
Posted: 02/17/21 01:26am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
JalynRohan wrote:
I already have a Champion 3400 ***Link Removed***. Does it sufficient while traveling?
I have this unit. It is a good value but the feature that makes it easy to handle also makes it easy to steal. I do use a heavy locking cable. If anyone knows of a suitable ready built cage I would love to hear about it.
pianotuna
Regina, SK, Canada
Posted: 02/17/21 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
AE5TE,
I had a cage made, after my Yamaha 3000 developed wings.
Teamjd
NY
Posted: 02/22/21 07:23am Link  |  Quote  |  Print  |  Notify Moderator
#1Flyboy wrote:
.... IF you buy a Honda you will pay more, but you will get more. Service, reliability, resale value and a proven generator. If you get a Communist China knockoff you will pay less but also get less and it might , maybe, produce the stated power output....
You do realize that Honda generators are made in Japan, China, Thailand, India, and US. While they are reliable and probably easier to get them fixed, it's pot luck where it was made.
Page of 7
