RV.Net Open Roads Forum: Tow Vehicles: Fords new 7.3 Godzilla
Search only in Tow Vehicles
 > Fords new 7.3 Godzilla
Page of 6
fla-gypsy
North Florida
Posted: 07/24/20 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
I will be in the market in a year or so and I’m a player for the 7.3L. My 09 6.8 V10 has been nothing but a good truck. With my 10k trailer the 4.10 rear has matched up nice. I see no reason to think the 7.3/10 speed with a 4.30 would not perform better
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
steve-n-vicki
arkansas
Posted: 07/24/20 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
I have 9200 miles on my 7.3, I pulled an enclosed trailer to Dallas and back was running about 70 mph I was getting 9.8 miles to the gallon , pulling a 82 inch wide by 16 foot long flat bed trailer was a John Deere 1025 on it or an altoz 660I zero turn mower, I get 15.2 miles to the gallon, on a straight level stretch of highway between my house an Beebe which is 24 miles I get 16.4 miles to the gallon empty, The truck is an F350 super crew long wheelbase
dodge guy
Bartlett IL
Posted: 07/24/20 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
2012 V-10 362HP@4750rpm, 457TQ@3250rpm
2020 V-8 430HP@5500rpm, 475TQ@4000rpm
Like,I said the numbers, although a bit higher do not seem to go well for an engine designed for hauling weight. All the power output is too high in RPM. And unless they are going to give you 100% throttle control, all that is useless if they are gong to pull the throttle opening back when you need it the most? Like they do with current and past motors.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
dodge guy
Bartlett IL
Posted: 07/24/20 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
And for comparison. My 02 Excursion V-10 with 3.73's and a 4 speed would do 15mpg. With 4.30's it did 14.3. Towing with 4.30's and a 5 star tune would do 7.5 towing a 35ft 9300lb 11.5ft tall trailer.
Posted: 07/25/20 12:19am Link  |  Quote  |  Print  |  Notify Moderator
Reisender wrote:
You gotta wonder, at least for the F150 half ton crowd, if this is just a stop gap until fords Electric F-150 hits the market in a couple years. Looking at the comments here about non towing MPG of under 20 MPG. Ugh. That is horrible for the performance you get. For those who don't need to tow a heavy trailer long distances but just want a good looking fast truck thats cheap to run and maybe drag the boat to the lake etc, the Electric F-150 is going to slay the gasser. 2022 is going to be interesting.
The Tesla towing thread is just down a few. May go hang out there.....
And don’t hold your breath the elect F150 will slay anything but an extension cord if you’re trying to tow with it. But nice thread jack!
2017 Heartland Torque T29
alexleblanc
Shediac N.B
Posted: 07/25/20 04:40am Link  |  Quote  |  Print  |  Notify Moderator
I’d like to see both graphs on beside each other as I believe the 7.3 makes more HP/TQ at the V10’s peak rpm levels, it just happens to keep making more HP/TQ at higher rpm’s.
TV - 17 F350 CCSB SRW Platinum 6.7 + 5er - 15 Durango 296BH + B&W Companion
others - 17 Shelby GT350 | 21 Expedition Max Platinum | 14 Mustang GT | 87 Regal GN | 37 Plymouth Coupe | 21 Maverick X3 DS Turbo R | 22 Cayman GTS 4.0 (on order)
dodge guy
Bartlett IL
Posted: 07/25/20 06:30am Link  |  Quote  |  Print  |  Notify Moderator
I do remember seeing it and you may be right. I just would've thought that for a workhorse motor they would've brought the operating range down below the current V-10! I'm sure it will tow better. I would love to see a side comparison in the real world and not on a drag strip (TFL testing).
blofgren
Surrey, B.C.
Posted: 07/25/20 08:02am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
Likes to tow wrote:
Been reading a lot about the new 7.3 gasser from Ford and it certainly looks impressive. People are reporting 15 mpg non towing. New diesels with all the emissions **** are not doing a whole lot better than that and at a cost of $8000 more for the diesel option. That would buy a lot of gasoline. The complexity of the newer diesels have changed my thinking on engines. I run an 05 Ram Cummins and will at some point buy a new vehicle. I raised the hood on a new F350 last week and could not believe how everything is jammed in there. Looks like this push rod V8 from Ford may be a real winner.
I just bought a brand new Ford F350 STX 4 door cab with 8 foot bed and the 6.7L turbo diesel paired to the new 10 speed transmission. First 400 miles I am averaging 19 MPG not towing. I've only towed our FW about 100 miles but the average was about 14 MPG. I would expect that my MPG will improve a little as it breaks in. It's a complicated engine but has proven itself for almost a decade and has an impressive warranty.
Thanks for posting; sounds impressive! What differential ratio do you have?
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
way2roll
Wilmington NC
Posted: 07/25/20 10:00am Link  |  Quote  |  Print  |  Notify Moderator
3.55
Posted: 07/25/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
The fact that it’s a close comparison between a 20+ year old engine and a brand new one is sort of funny. The OEMs aren’t after any power wars with their gassers and the 7.3 is nice, but it’s a hell of a big motor for such little power.
Either they don’t care, or they tuned it down waiting for the others to catch up and then will be able to bump it up a bunch of times at little to no cost on their part.
Page of 6
