RV.Net Open Roads Forum: Generac GP3300 modifications
 > Generac GP3300 modifications
Mojogosrving
Washougal, WA
Posted: 02/23/20 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all,
I am really disappointed with my generator. did not know the watts were spit and it wont even run my microwave in my rv. my microwave wattage is 990w. should of been plenty if it were 3300 watts. but instead, it is 1600. my gen surges when micro is on, then eventually the breaker trips.
Is there any way to bypass the split so that the gen will run on the full 3300 watts?
Thanks for any advice!!
MrWizard
Traveling
Posted: 02/23/20 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes
The output wiring from the generator head connections
Can be changed from (center tapped series 230v Split load )
To (parallel 115v only full power)
You are still limited to circuit breaker limit going to that duplex outlet
Need to see the wiring diagram and a picture of the wiring from head to terminal block to outlets
It has been done before, depends on the generator
It's strange that 1600 Watts won't power your MW
Did you check the fridge is on propane
And that the converter is off and not charging the batteries, also some water heaters have an electric option
Everything that can use propane instead of electric
Should be set to propane, Not electric or automatic
* This post was edited 02/23/20 02:24pm by MrWizard *
Radiate The Happy
1997 F53 Bounder 36s
ScottG
Bothell Wa.
Posted: 02/23/20 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Is the cooking power of your micro rated at 990W? If so then the power used could easily be 1500~1600 watts overall.
theoldwizard1
SE MI
Posted: 02/24/20 09:30am Link  |  Quote  |  Print  |  Notify Moderator
From one Wiz to another ...
MrWizard wrote:
Sometimes ...
Not likely. The stator on alternating current generators is wound with one continuous wire that is center taped. This is a single phase that is "split", hence the term split phase.
I don't know enough about "electric power generation" (not covered in any of my EE courses) to know if you can simply "fold" the second half of the wire back on to the first half.
I guess you could test this if you had a good meter (oscilloscope would be better) by ...
• Start the generator, turn the fuel off and run the carburetor bowl dry
• Connect L1 to L2 on the 240V outlet
• Remove the spark plug (zero compression)
• Pull the cord as hard as possible
• If you are reading close 120V then you should be good.
If there is any type of electronic voltage regulation it could be a problem !
MrWizard
Traveling
Posted: 02/25/20 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Old wizard its very common construction
All 4 leads of the two windings, are brought out of the head ,
L1 is one hot leg L4 is the other opposite hot leg
L2 & L3 are tied together as the neutral
Even Onan does this
L1 to L4 is 230v
Connect L1 & L3. Together
Connect L2 & L4. Together
The windings are now parallel
115v full ouput
L1/3 is used as the hot
L2/4 is used as the neutral
Will have to move a circuit breaker wire from L4 to L3 to parallel the breakers or one breaker will be in the neutral side of output
Can also replace the two separate breakers with one larger one
Depends on what breakers and sockets/outlets are mounted in the generator face plate
* This post was edited 02/25/20 09:07pm by MrWizard *
KMLsquared
Cotati CA
Posted: 02/25/20 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
My generac has separate windings that can be wired 110 or 220.
* This post was edited 02/26/20 08:28am by an administrator/moderator *
2002 Doge RAM LB QC 4x4 HO 6spd
2003 Rampage 33TB
2007 CRF80F
2006 TTR50E
2004 CRF70
2002 TTR125L
2002 Banshee
1969 Baja Bug
Rvpapa
Alberta , Can.
Posted: 03/03/20 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
If it is surging now, putting windings in series for full output as 120VAC is not going to change anything. Get engine running and governed smoothly and your microwave will probably be happy.
Art.
Rvpapa
Alberta , Can.
Posted: 03/04/20 11:59am Link  |  Quote  |  Print  |  Notify Moderator
Edit above reply to correct for a senior moment. change SERIES to PARALLEL [emoticon]
Art
