RV.Net Open Roads Forum: Class A Motorhomes: Ramco Mirror - unable to remove
 > Ramco Mirror - unable to remove
Nutinelse2do
On the Road Where the Weather Suits Our Clothes
Posted: 02/23/20 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Good day all,
Need to remove my drivers side Ramco mirror in order to repair the mounting.
I have removed the bolt on the bottom under the cover and the mirror wont budge.
I contacted Ramco and they said soak it with WD 40 and hit it with a rubber hammer in several places below the first knuckle. I have been doing this twice a day for 3 days.
Still no movement
Any other ideas?
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
Executive
Posted: 02/23/20 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Get a bigger hammer....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Kern County, CA
Posted: 02/23/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Only sissies use rubber hammers.
enblethen
Moses Lake, WA
Posted: 02/23/20 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
I am guessing these are the instructions from Remco!
Removal of Arm from Mounting Bracket
1. Locate cap with Ramco logo on bottom of mount covering (shroud) and remove using a small flat-head screwdriver. This will expose the bolt that attaches the arm to the mount. 2. Using a 9/16” socket, remove the bolt. 3. Once the bolt is removed, lift the arm out of the mounting bracket. If the arm does not come out easily, use a rubber mallet and tap on the bottom of the arm to loosen it. 4. Once the arm has been removed, disconnect the wire harness. If there is not a quick disconnect, the wire will have to be cut. Be sure to allow enough slack in the wire so when reconnecting there will be enough wire to work with. (Allow about 4-6” out of mounting bracket and 3-4” out of arm.
I would get something other then WD-40. Need something like Liquid Wrench. It needs to break aluminum oxidation.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Nutinelse2do
Posted: 02/23/20 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you very much. Simple enough to try !
eheading
Lakeland, FL
Posted: 02/23/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
What I do is loosen the large bolt under the mirror. Then I put a nut inside a socket with an extender on it. The nut inside forces the socket to sit on the bolt head not the mirror. Then I smack the extender with a hammer, and for me, the mirror pops up. Then I just remove the bolt, and lift out the mirror and unplug the electrical connections.
Ed
DFord
Near St Louis, MO
Posted: 02/23/20 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
PB Blaster is the best thing I've ever used to to break things loose other than heat. You could try heating it up as much as you dare and soaking it with PB Blaster right away. That seems to draw the penetrant in better. Backing it up with one larger hammer while hitting the other side might help.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BarabooBob
Baraboo, WI
Posted: 02/23/20 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
A product called Freeze Off super cools the bolt. Follow this with heat and cool again. I have gotten parts loose using this method. Another option.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
dougrainer
Carrolton, Texas
Posted: 02/24/20 05:59am Link  |  Quote  |  Print  |  Notify Moderator
I have NEVER had a mirror gaul(freeze) to the mount. I will bet the OP has NOT loosened the allen wrench adjustment screws on the side of the pivot. THOSE will not allow the mirror to release when the bolt is removed. Doug
Executive
Posted: 02/24/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Those adjustment screws are hidden behind plugs so they're often overlooked....Dennis
