RV.Net Open Roads Forum: Class A Motorhomes: Ramco Mirror - unable to remove
 > Ramco Mirror - unable to remove
Nutinelse2do
On the Road Where the Weather Suits Our Clothes
Posted: 02/24/20 09:58am Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
I have NEVER had a mirror gaul(freeze) to the mount. I will bet the OP has NOT loosened the allen wrench adjustment screws on the side of the pivot. THOSE will not allow the mirror to release when the bolt is removed. Doug
Sorry Doug, not a Velvac mirror, so there isn’t any. The OP thanks you for your fine advice? And what’s with the snarky Dennis?
I always say, this is the last post on this forum... well now it is.
Thanks all for the helpful advice, and thanks again for reiterating the reason this forum is dying and people are leaving in droves
Best of luck to you all and safe travels,
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
dougrainer
Carrolton, Texas
Posted: 02/24/20 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Ramco have them too. They even state such in their on line troubleshooting. Doug
Removal of Arm from Mirror Head
1. Loosen the set screws located on the arm that holds the mirror head in place. (3/16” Allen
wrench)
2. Pull arm off the mirror head. Two aluminum halves that go around the ball stem will be exposed
and become loose. Place those to the side.
3. If there is a plug on the end of the wire harness, an AMP deplugging tool will be needed to
remove that plug. (Be sure to note sequence of colors) Otherwise, remove wire harness from
arm.
Westenthal
Springfield, IL
Posted: 02/24/20 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Mine just fell off. New aluminum casting and $3K for repairing side where mirror was banging against coach before I could get stopped and all is well again. Didn’t pull any wires loose, just scratched the heck out of drivers side.
Westenthal
