RV.Net Open Roads Forum: Tech Issues: Replacing TT AC
 > Replacing TT AC
rfloyd99
Posted: 02/26/20 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
I have to replace the rooftop part of my four year old Dometic AC. It went out last Summer and I'm just now getting around to it. Back then I did some research and it seemed there were several places to buy one, at around $475-500.
I plan to do the work myself. I'm pretty handy, but not a pro. An RV tech told me it was a fairly simple job.
Anybody have experience with this? Advice on where to buy, is used an option, installation tips, etc. would be greatly appreciated.
rfloyd99
Posted: 02/26/20 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
OP here. Before posting I did a search but didn't try too hard. After posting I searched better and found a recent post on this issue which answered most questions.
But, anyone have ideas on best place to buy this expensive item? Is there a place that sells used or reconditioned ones?
ScottG
Bothell Wa.
Just curious, why do you need to replace it?
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Mike134
Elgin
Posted: 02/26/20 03:13pm Link  |  Quote  |  Print  |  Notify Moderator
etrailer.com has good pricing on stuff I've bought. have not searched for an A/C however
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
rfloyd99
Posted: 02/26/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
ScottG, after owning the trailer (bought new) 3.5 years with only moderate AC use, a capacitor failed. Dometic's genius designers made this a non-replaceable part, so the entire unit must be replaced.
We were sitting in an RV park with the AC running on day two of a long trip, when I smelled that "electrical fire" smell. The fan continued to work, but no cold air. As far as I know, there was no cause other than poor design, or poor workmanship at the factory. I use a surge protector, so I doubt there was a problem with the power.
I sent a long email to Dometic, hoping they would offer something toward repair since this was a no-moving-part item that shouldn't have failed with so little age or use.
Of course, their response was basically "too bad".
Matt_Colie
Southeast Michigan
Posted: 02/26/20 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Rfloyd,
Not being a replaceable part means one of two things:
The manufacturer does not supply an identical part to replace it.
OR
The failed part is buried in an assembly that make replacement very difficult.
Neither of these is a reason to scrap the entire unit. Do you have a friend (or even a friend of a friend) that is an electric or HVAC smart person??
Offer said something of moderate value (dinner or glass encased substance) to look at the unit and see if he has an idea.
Capacitors are nothing special. It pretty much has to be external to the refrigerant circuit, but it might be a physical problem that needs a creative solution.
I am distressed that Domentic doesn't want to help you, but that is their choice. Oh, and when you get this figured out, sell the plan. There is nothing that they can legally do to stop you from selling a repair part that they will not supply.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
ScottG
Bothell Wa.
Posted: 02/26/20 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
Wow, hadn't heard of that. Pretty crummy on their part.
Best of luck to you!
Scott
rfloyd99
Posted: 02/26/20 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Matt, thanks for the suggestion, I plan to look into that.
I talked to one place that was a Dometic warranty station. The person was nice, but said they couldn't even look at it for a quick diagnosis for three weeks. He was very helpful and took time to answer several questions. He said it sounded like one of the two capacitors failed. One is a replaceable part, the other is not. He predicted only a 30% chance that it was the replaceable one.
I took it to a large RV dealership service department, the tech went right to the problem and said it wasn't a replaceable part. There are two similar looking electrical components at the top of the compressor (easily accessible). On one of them there was a short, I guess, that burned the wire off of its terminal. The two components were covered by a heavy plastic cap to shield/insulate them, so I don't see how there could have been a short, or anything else that caused the little fire that melted the wire.
It looks like the terminal is damaged, but maybe somehow the wire could be reattached. But I don't know what the underlying cause was, so perhaps more is needed than just reattaching the wire. I have photos of this, if anyone would like to see them.
Thanks for your response, I really can't afford the cost of replacement, but have to fix this before our trip this Summer.
DFord
Near St Louis, MO
Posted: 02/26/20 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Do you know the model number on your Dometic air conditioner? I've been repairing air conditioners since 1966 and can't imagine a non-replaceable run capacitor. I'd like to look into that some more. Unless the terminals are burnt off the compressor, seems like you'd be able to hang a run capacitor in there somewhere and bypass the original even if it wasn't removable. Any way you could post a picture?
Where are you located? I'm just south of Miami right now.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
sayoung
Tx
Posted: 02/26/20 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
I started the summer of 65.
I also can't get my head around an irreplaceable run capacitor. Even if " true ", any AC tech worth a flip should be able to work around that if the compressor wiring near the terminals is accessible...
 > Replacing TT AC
