RV.Net Open Roads Forum: Travel Trailers: Xchocks question
 > Xchocks question
Kern County, CA
Posted: 02/27/20 09:15am Link  |  Quote  |  Print  |  Notify Moderator
“They get tossed into the back of the truck so that thy are easy to get if we park on a steep incline.”
A good safe practice. I see many newbies not at all concerned. They don’t even turn their front wheels into the curb when available. I moved once to get uphill from one airhead
tdiller
usa
Posted: 02/27/20 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Snomas wrote:
Do I need use one or two X-chocks? I have always used plastic wheel chocks to keep TT from moving when camped but like the between dual wheel X chocks.
I use two.
Huntindog
Phoenix AZ
Posted: 02/27/20 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
I tried the store bought brands when I first started. For the last 20 years or so, I ahve been using homemade ones. Two 4x6s cut into a wedge with a large 12-14' bolt and nut to tighten them. A lot of times I don't need them. When I am off level, I dig holes for the high side wheels. Lots of advantages to doing it like this. The TT cannot fall out of the holes, like ican off of blocks. The TT sits lower which is better for the steps and stability in wind. The only thing needed is a shovel which is a handy thing to have in camp anyway.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2011 Silverado CC DA big dually.
spoon059
Just north of D.C.
Posted: 02/28/20 11:17am Link  |  Quote  |  Print  |  Notify Moderator
X-Chocks are meant to reduce the rocking sensation by preventing minor rolling of the wheels. They are NOT meant to replace actual chocks, which are meant to reduce the trailer from rolling away.
I use Fastway wheel chocks, as it does BOTH. It is an actual chock that prevents the trailer from rolling away and it reduces the rocking sensation by not allowing the tires to have that minor roll.
2015 Ram CTD
2015 Jayco 29QBS
hondapro
Central Pa
Posted: 02/29/20 05:37am Link  |  Quote  |  Print  |  Notify Moderator
Throw the cheep plastic chocks in the nearest garbage can, get 4 of the hard rubber chocks from harbor freight.
Set the chocks properly,I set the rear chocks and slightly back into them then I set the front chocks put the truck into neutral and let it set into the front chocks the put the x chock in.
Steve
2016 F-350 6.7 Diesel
2015 Springdale 311RE
parcany
Arizona City
Posted: 03/01/20 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Don't take this the wrong way but it would be kind of hard to dig holes under the high side wheels when you are in a state campground when the parking area is tar. Out in the boonies would be ok. I use a homemade set of 4x4 chocks and the store bought x-chocks and it works out just great. Never had the trailer even think about moving while unhitching it.
beemerphile1
Ohio
Posted: 03/01/20 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
I see some are recommending the rubber chocks from Harbor Freight. I have them and don't like the design or shape. I recently got some chocks from Tractor Supply that I believe will be much better.
https://www.tractorsupply.com/tsc/produc........tural-foam-poly-chock-ts239?cm_vc=-10005
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
rbpru
North Central Indiana
Posted: 03/02/20 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Quite frankly I have never found trailer movement to be an issue. I set the chocks as needed for the slope of the ground and that is that.
Perhaps it has never been an issue because I have a shorter 25 ft. 6500 # TT.
Even my worst case in KY where I had the tongue 30" off the ground and the back bumper off the ground by mere inches caused no TT movement.
I have driven over my chocks a few times but those cheapo yellow plastic types pop back after a few days.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
jdc1
Rescue, Ca
Posted: 03/02/20 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Walaby wrote:
Xchocks are not supposed to be a "replacement" for regular wheel chocks.
Mike
Ditto......they cannot hold the weight of an RV trailer unless it's a Casita or Bollero (2,000 lbs).
plasticmaster
Home
Posted: 03/05/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Here's my homemade x-chocks for my spread axle travel trailer. Without the chains and turnbuckle, the wheels still move and I get a seesaw effect of the chocks when I push the back of the camper. With the chains and turnbuckle, the wheels are held rock solid and don't move when I push on the back of the camper.
 > Xchocks question
