RV.Net Open Roads Forum: Fifth-Wheels: Water Heater Relief Device
 > Water Heater Relief Device
ford truck guy
Pennsylvania
Posted: 03/04/20 05:45am Link  |  Quote  |  Print  |  Notify Moderator
I have found over the years that IF they start leaking there usually are 2 ways to go ( in my eyes)
1- open and close the valve a few times, sometimes a small piece of debris will be stuck there allowing for a leak..
2- more likely you will have to replace the valve, which is quick, easy and painless.
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
wildtoad
Blythewood, SC
Posted: 03/04/20 06:31am Link  |  Quote  |  Print  |  Notify Moderator
I had the same problem with my Suburban WH and no procedure worked to fix it. There is nothing wrong with your valve most likely, it is a design issue with the water heater IMO. Suburban knows it’s a problem, says so in their manual, and has no plans to correct this feature. I struggled with this issue for four years and finally took Suburbans work around their problem solution.The only solution is to install a small pressure tank inline with the water heater. The pressure created by the heating of the water is absorbed by the tank and not blown out the relief valve.
I never had this pressure relief issue with an Atwood in five other motorhomes.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Esacnj
NJ
Posted: 03/04/20 07:10am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all. I will try to re establish air pocket.
alboy
Kelowna B.C.
Posted: 03/04/20 07:19am Link  |  Quote  |  Print  |  Notify Moderator
OUR suburban was doing the drip from the relief valve , did a complte flush ,no help, changed the thermostat , fifteen minute job , no more issues
Cummins12V98
on the road
Posted: 03/04/20 08:53am Link  |  Quote  |  Print  |  Notify Moderator
"1- open and close the valve a few times, sometimes a small piece of debris will be stuck there allowing for a leak."
We think too much alike!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ford truck guy
Pennsylvania
Posted: 03/04/20 09:08am Link  |  Quote  |  Print  |  Notify Moderator
"We think too much alike!"
for the most part... Who knows, perhaps your my long lost brother from the other coast ! :-)
cummins2014
Utah
Posted: 03/04/20 09:36am Link  |  Quote  |  Print  |  Notify Moderator
That’s the first thing I did, open and close. Mine had just got bad would not seal . Yes it’s easy and inexpensive to replace . I didn’t mess with mine much , just replaced it .
pyoung47
MO
Posted: 03/04/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
Once tripped, they will often leak a bit. My trailer is an outdoor dog, so it’s not a big deal. If you are anal, replace it — and in due time, it too will dribble.
Old-Biscuit
Verde Valley
Posted: 03/04/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
