PA12DRVR
Back in God's Country
I used the braided extensions for about 5 years...never had an issue with leaking.
Sold that truck and (brain fart) let the extensions go with it. I used the "1 inch" or something like that straight extensions on the inner tire on the replacement truck. Worked out fine for another 5 years before I sold that rig.
After a gap of about 6 years, my only dually is my F550 plow truck. Since I only have to add air about 1x per year, I use the double-headed chuck. Works for that situation, but I may eventually put extensions on the F550 as well.
CRL
My RV is a 1946 PA-12
Back in the GWN
fj12ryder
Platte City, MO
Cummins12V98 wrote: fj12ryder wrote: I tried 3 sets of flexible extensions and they all leaked, some sooner than others. Finally I just gave up and found an angled air pressure gauge that works very well. And a filler with the same angled head.
The chuck linked to above wouldn't work for me, I use this one: Straight Head
It wasn't a link. THAT takes a computer EXPERT that I am NOT! That is exactly what I was referring to. Oops, sorry about that. This is what I came up with when I did a Google search for the product you listed:
Angle head.
Hey, whatever works is what I say.
Howard and Peggy
"Don't Panic"
Cummins12V98
on the road
Look the same are they different?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
klr650goldwing
minnesota
Okay, I purchased the correct chuck and I can see how it WILL work to air up both inner and outer tire on the rear. However, I can't get my hand in to remove the valve stem cover. I tried a needle-nose plier, a regular plier and neither would do the job. Is there a special tool for this task or do you have a very small hand available to help out? How do you remove the valve stem cover on the inner dually?
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
Cummins12V98
on the road
My RAM does not have caps on inner rear tire valve stems. Simply push on air chuck and fill or deflate.
NJRVer
NJ
klr650goldwing wrote: Okay, I purchased the correct chuck and I can see how it WILL work to air up both inner and outer tire on the rear. However, I can't get my hand in to remove the valve stem cover. I tried a needle-nose plier, a regular plier and neither would do the job. Is there a special tool for this task or do you have a very small hand available to help out? How do you remove the valve stem cover on the inner dually?
I found on my Ram it's easier to reach behind the outer dually between the two tires to get the cap off than to try and get it off through the hole in the outer rim.
fj12ryder
Platte City, MO
klr650goldwing wrote: Okay, I purchased the correct chuck and I can see how it WILL work to air up both inner and outer tire on the rear. However, I can't get my hand in to remove the valve stem cover. I tried a needle-nose plier, a regular plier and neither would do the job. Is there a special tool for this task or do you have a very small hand available to help out? How do you remove the valve stem cover on the inner dually? I use a piece of flexible clear tubing just big enough to be a snug fit around the valve stem cap. I simply push the tube onto the cap and unscrew it, and vice versa when putting it back on. Works a treat.
fj12ryder
Platte City, MO
Cummins12V98 wrote: Look the same are they different? The one is a straight shot down the tube to the valve stem, the other is at an angle and won't work with my valve stems.
klr650goldwing
minnesota
My hand will not fit between the two dually tires.
Travlingman
Jonesborough, TN
On my 2017 King Ranch, the valve covers don't have to be taken off. You can air your tire up through them.
2017 F-350 King Ranch DRW
2014 Landmark Savannah
