Wherever I happen to park
No matter the location right left or center the good news is that magic word WARRANTY.. Glad it happened that way .. May the "Total bill $0.00" be with you.
Home is where I park it.
garyemunson
Reno, Nevada
Might as well flush the entire brake system while you are at it, Ford manual calls for every 2 years.
jeeperdude10
N. Georgia
Has anyone done the 'gravity' method of brake fluid replacement? I am wondering if this may be do-able on my '16 F53.
2016 Bounder 35K
2014 Freedom Edition JEEP Unlimited
Traveling thru this great country
johnhicks
Wandering below the Gnat Line
When a master cylinder has an external leak it'll leak between the cylinder and the hydroboost; that's why there's a weep hole there so if either leaks it won't contaminate the other.
The solution of course is to replace the master cylinder. Then I'd completely drain and refill the brake system since you'll be seriously bleeding it anyway.
It's a failure, no way normal wear and tear.
Spray everything with VHT rust converter or paint with ospho.
-jbh-
johnhicks
You might be able to see the level of the fluid in the master cylinder reservoir by putting a bright light behind it.
Lt46
Central Florida
For me, my master cylinder failed 2 weeks ago. Internal leak, no fluid loss but pedal to floor with minimal braking action. This MC was the OEM and my moho is a 1997. Aside from working in a tight space, replacement was a breeze.
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
Tim Nowicki
Alden NY
Gravity bleed was always the way to go for me. When you work alone you make things work. BUT with modern day vehicles I don't know if gravity bleed will still work.
JoeH
Apollo Beach,FL
While not and F52, I had the master cylinder fail on my 2015 F150 .
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
dodge guy
Bartlett IL
Still have the OE master cylinder in my 01 Explorer with 200k miles. But I flush he brake fluid often as did the original owner.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
MetalGator
I got the motor home back from the Ford dealer yesterday. They had to replace the brake master cylinder at just over 11,000 miles. They said the tank was leaking at the seam. I guess the tank and cylinder are one piece as they replaced the whole unit. At least it failed while I still have a few months of warranty left. Didn't cost me anything.
2018 Miramar 35.3
2005 Dodge Ram Quad Cab 1500
3 fur kids (Monty, Lola and Pinto)
Rainbow bridge (Murphy)
