Ivylog
Blairsville, GA and WPB, FL.
No telling how many people Doug has helped over the last 13 years he’s been on here giving excellent free advice. Many of his replies to a problem is longer than this post.
Recently I PM Doug on a problem... one AC short cycling in my 08 Navigator... rear Duotherm (1 of 3 old style on a 5 button Tstat) short cycles on AC...other 2 do not. Will start up multiple times... long enough for compressor to start and then immediately shuts off. Occasionally it will run for 10-60 seconds before shutting off. If I lower the temp several degrees lower it will start and run until it gets to the new lower temp and then start doing the same thing. I’ve covered the remote temp sensor with tape but doesn’t make any difference. Any suggestions on what to do???
Doug’s reply; take the remote sensor out of the wall and let hang. IF the sensor has a plastic clamp to keep from falling in the wall remove that plastic clamp. ANY pressure on the bulb of the temp Thermister will cause erratic operation including short cycling. Doug
THANKS, there wasn’t a clap real close, but the bulb was touching the cover. Repositioned and will see, once it cools down, if that fixes it, Problem Solved
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
hypoxia
Arizona
Doug is a fantastic help to this forum!
Jim
2007 Monaco Signature Noble III ISX 600HP
wolfe10
ABSOLUTELY-- A great, professional help.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
johnsonbert
Houston, TX-Ironwood, MI
I agree. His posts have helped me several times. Thanks Doug
Happy Trails Bert
2006 Monaco Dynasty Diamond IV 42' Tag, ISL 400,(new to us), Residential Refrig, 10KW Onan, Bosch Washer/220V Dryer (previously 2003 American Tradition 40W) 2010 Chev Malibu LT
DFord
Near St Louis, MO
wolfe10 wrote: ABSOLUTELY-- A great, professional help.
X2! Thanks to Doug for taking the time to help everyone here with his expertise! It hasn't gone unnoticed.
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
Gundog
Ridgefield, Wa
Doug took the time to help me the other day also thanks Doug.
2005 34' Expedition Cat C7 Allison 3000
ferndaleflyer
everywhere
Yes! He has helped me a few times and he is not selfish with his info and it always seems to be spot on....Must have worked on these things a long time
JoeH
Apollo Beach,FL
Yes, I've learned a lot from reading his posts. They are accurate and to the point. Thanks Doug !
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
Lt46
Central Florida
Couldn't agree more. Just last week I posted a furnace problem and in 2 posts he had me up and running. Thanks again Doug!
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
dougrainer
Carrolton, Texas
ferndaleflyer wrote: Yes! He has helped me a few times and he is not selfish with his info and it always seems to be spot on....Must have worked on these things a long time
41 years and still working. Doug
