RV.Net Open Roads Forum: General RVing Issues: Water softner setup
 > Water softner setup
M.R.E.
MI, usa
Posted: 03/06/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
What is the correct way to use a water softner ? A water filter before, after or both.
toolmaker
bobsallyh
Livingston, TX.
Posted: 03/06/20 10:31am Link  |  Quote  |  Print  |  Notify Moderator
I run the filter before the softener. You really don't want "bits and pieces" going in your softener.
Old-Biscuit
Verde Valley
Posted: 03/06/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
YEP^^^^^^
Pressure regulator at spigot/hose bibb......in-line filter(s)....softener....then RV 'city water' inlet
OR...after softener just fill the RV Fresh water tank, secure the CG supply and run off fresh water tank/pump
US NAVY------USS Decatur DDG31
eHoefler
ozark mountains
Posted: 03/07/20 06:42am Link  |  Quote  |  Print  |  Notify Moderator
The water softener is a 10 micron filter, when back flushed, all cought debris is flushed out. In my house I run a 20 micron before, and a 5 micron charcoal after. In the fifth wheel I don't use a filter before, but I do use a 5 micron after. I wind up regenerating my softener every 7-10 days, and back flush it every other time.
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
ncrowley
Utah
Posted: 03/07/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
As others have stated, you want the filter before the water softener. We have a sediment filter and a charcoal filter before the softener.
Nancy
Newmar Northern Star
Ro"n"Joe
Full Timing
Posted: 03/08/20 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Agree with filter prior to softner and I like having the pressure regulator plumbed in the wet bay. One less thing to setup upon arrival.
2020 Dutch Star 4328 on FL Chassis
2018 Grand Cherokee Limited
Ready Brute Elite Towbar & Road Master Wiring
