RV.Net Open Roads Forum: Dinghy Towing: jeep wrangler - where attach safety cables??
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > jeep wrangler - where attach safety cables??
Oregon Viatorem
Hood River, OR
Posted: 03/09/20 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
I'm prepping to flat-tow my 2015 Wrangler Rubicon JKU. I want to attach my coiled safety cables to the frame rails, but the jeep has an aftermarket front bumper, and no "slot" or other anchor point in the side of frame rails.
I'm looking for suggestions, experience, wisdom with this. Is it possible to add an anchor point somewhere - other than the bumper?
I suppose I could install anchors on the bumper, but that kinda defeats the purpose of the safety cables if its the bumper that fails.
thanks!
enblethen
Moses Lake, WA
Posted: 03/09/20 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
What base plates are you using?
Base plates normally have a place to connect safety cables.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Oregon Viatorem
Hood River, OR
Posted: 03/09/20 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
I attach my tow bar to the shackle/recovery tabs on the bumper. Its a beefy aftermarket offroad bumber with a winch, etc.
Was easy with my old Wrangler - my cables attached to a slot in the frame. Easy-peezy.
timmac
Las Vegas
Posted: 03/09/20 09:13pm Link  |  Quote  |  Print  |  Notify Moderator
X2
Your base plate has the hooks to attach the safety cables..
wildtoad
Blythewood, SC
Posted: 03/10/20 06:28am Link  |  Quote  |  Print  |  Notify Moderator
I’m pretty sure he is not using a base plate.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Oregon Viatorem
Hood River, OR
Posted: 03/10/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Correct. I apologize if I didn't make that clear in my post, or my 1st reply. [emoticon] I am NOT using a base plate.
To re-frame my question: to anybody that has experience attaching safety cable to a jeep wrangler with an aftermarket bumper (ie, not the factory bumper) and NO base plate - HOW do/did YOU attach the safety cables?
Y-Guy
Tri-Cities, WA
Posted: 03/10/20 08:31am Link  |  Quote  |  Print  |  Notify Moderator
You need to attache it to the frame rails some how. You might check out this option from eTrailer
enblethen
Moses Lake, WA
Posted: 03/10/20 08:36am Link  |  Quote  |  Print  |  Notify Moderator
What attaches he after-market bumper to the frame?
What kind of tow bar attachment to the Jeep?
2manytoyz
Central FL
Posted: 03/10/20 09:51am Link  |  Quote  |  Print  |  Notify Moderator
All aftermarket bumpers are not created equal. Mine is made from 3/16" steel, and bolted to the frame rails in multiple places, with grade 8 hardware. The hitch will likely tear free from the motorhome before the Jeep bumper comes off.
I had considered drilling two holes on the bumper bottom lip, and using shackles. But I decided to use the fairlead roller on the winch to mount the safety cables. This is also 3/16" steel, and uses 4 grade 8 bolts.
Take a look at where the safety cables/chains attach to the MH tow hitch. There's the weak link in my case. YMMV!
Robert
Merritt Island, FL
2015 Forest River Georgetown 328TS
2006 Jeep Wrangler Unlimited TOAD
Falcon 2 Towbar, Roadmaster 9400 Even Brake System
http://www.2manytoyz.com/
RJsfishin
Winston Or.
Posted: 03/20/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Its not rocket science, just attach them !!
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
