RV.Net Open Roads Forum: If I went to a Progressive Dynamics Converter.......
 > If I went to a Progressive Dynamics Converter.......
BFL13
Victoria, BC
Posted: 03/14/20 09:56am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
BFL13,
Do not run an alternator without a battery. The diodes die if you do.
My point was whether he has some load right off the battery that the alternator is not taking care of, which would not happen in an RV set-up for the house side.
LY has his battery doing both engine and house. Might explain what he is seeing, don't know.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
landyacht318
Near a large body of salty water
Posted: 03/14/20 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, not going to turn battery switch off with engine running.
Back when I first got the hall effect dash ammeter I had the sensor measuring total alternator output, not like today where it islocated to measure amps into or out of battery. One day I was heavily discharged and driving intentionally keeping rpms up, and the 140 amp circuit breaker tripped after ~5 minutes of 65 to 120 alternator amps. This rather extreme load dump did not fry the diodes in the alternator and it worked fine for 4 more years once I reset the CB.
The regular parallel OEM charge circuit was disconnected for measuring the total alternator output so it was a true load dump. My meter is only rated for 100 amps, if I go over 100 amps it reads
It was reading that at 14.1v+ at 2200 engine rpm when it went to -20 amps when the CB tripped well below its rating of 140 amps.
I bet the observation of slight discharging at float with heavy dc loads running, can be repeated without engine running. Put a 25 amp load on dc system with converter holding battery fully charged battery at 'perfect' prescribed float voltage, and the battery will still partially feed some of that 25 amp load and not remain at 100%SOC, but fall to some level slightly below that.
As I said its not much, and not really consequential, at least to me. Just an observation.
The way my rig is wired, my 1/2/both/OFF LOAD switch, is closer to my 1/2/both/OFF ignition switch, than it is to my battery and on equally thick cable, and no other wires, but the voltage sense line, goes to the battery terminals. No loads bypass the Ignition Switch or the LOAD switch to go directly to the battery. I doubt the voltage sense line's current is even measurable with any tools at my disposal, and the 20awg I am now using for it is way overkill.
My dashboard calibrate-able 00.00x voltmeter now has 20awg ground and voltage sense wires going to the battery itself well the ground still goes to my shunt's buss bar, but until recently, took a ground much more closely to the voltmeter. I employ a 10 turn potentiometer to adjust the alternator's voltage regulator, at a steady rpm it is pretty easy to dial battery voltage in to the hundredth of a volt, most of the time, exceptions being when it is near full and it bounces around a few hundredths easier.
Dash hall effect ammeter has drifted just recently, reading high, but this AGM continuing to taper to 0.0x amps at absorption or float when full is a constant. Same as on my previous NSB-27m until ~8 months before I removed it from the rig and relegated it to light cycling duty in the workshop. at end of Rv duty Amps would never taper to 0.4 and would bottom out over 4.0 amps then start rising again going as high as 13 amps if I was not there to lower voltage from 14.7v.
I kept using it until it struggled to start my engine fully charged on a warm day with a warm engine. Voltage retention on regular overnight discharges were as good as ever and it still is impressive in workshop in this regard. If I were to judge this battery's health
only by the voltage retainment on regular overnight discharges, I would be unaware of its decline. Which is surprising and unexpected, and impressive really.
Since being relegated to workshop and light cycling and a 100 watt panel facing south being the main recharging source, the amps will taper to ~1.4 before bottoming out and then rising when held at absorption, and improvement from when it was taken from my rig, where it was discharged deeper regularly.
Drifted far from the PD converter topic, apologies.
* This post was edited 03/14/20 02:54pm by landyacht318 *
Mobilesport
Iowa
Posted: 03/15/20 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 03/15/20 12:34pm by Mobilesport *
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 03/15/20 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Alternator only in danger if it has a voltage regulator with remote sensing. All of my systems have intergral sensing.
Load-dump causes rectifiers to fail not running with correct voltage reference. Running with batteries cut out from voltage regulator sense broken or switched off can cause deadly AC voltage. Hundreds of volts and several dozens of potential amperage within the cut output wiring. Yes I mean deadly.
mchero
Henniker, NH
Posted: 03/25/20 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
Doesn’t sound like much of an upgrade for a bunch of money and time.
Sounds like a FANTASTIC upgrade!
I purchased a 93 Pace Arrow Diesel that had 4 toasted 6v GC batteries. Canned the charger and went with a Progressive Dynamics 60aml model with the charge wizard.
If your not 100% sure about your house batteries replace them!
I installed the PD and purchased 4 Sams Club GC 6 volters.
Make absolutely sure you cables are 100%. I got 12 years off that set of batteries!
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
babock
Los Angeles, CA
Posted: 03/25/20 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
You just use a transition post to change the size of wire right before the converter. Not a big deal. Run 1/0 wire from the battery to the post and 4AWG or 6AWG from the post to the convertor for the last foot.
Vintage465
Prunedale CA.
Posted: 03/26/20 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
That's what I was thinking.......
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retiring in 2021, then look-out road, here we come!
